Transponder Phillips crypto ID46
Astra H can not programme transponder keep saying write with virgin chip any idea? I tried using opcom and x100+ and will not programme keys.
What?s the solution, thanks in advance?
Note:All information given is to be used for educational purposes only and should not be taken seriously.
Needs to be a remote key. You can't program a normal pcf7936.
super jumbe (7th July, 2015)
you need pre coded a pfc7936 with remote key,
i program these with avdi or opcom. I dont precode them or anything, they come from my supplier & just program straight in. Its from a local supplier, Ive never been able to find a cheap chinese version
on Astra H? this is pcf7941.
Have you read key(virgin) with some external programmer? I did it once with zedbull and f... key.
If you can't program try to delete keys and add first new then old keys.
I have bad experience with X100+ and OPEL, it deleted keys on ASTRA G but I could not program them back had to use tech2, also op-com doesn't work 100%
kappa1 (29th August, 2015), mikajna (8th October, 2015), super jumbe (7th July, 2015)
opcom has worked 100% for me, but sometimes if all key spaces are used, they need to be deleted first. I actually just did one 5 minutes ago & the original key was a pcf7941.
I usually use avdi to do keys though because opcom doesnt get the pin. avdi has never failed me on these and is pretty simple to use, I never precode anything, just learn in a new key & it works
I checked it is pcf7941 tried deleting all keys still an issue, keep nagging use virgin key. I am going to get new keys this morning and will keep you updated.
reading these damages them.
This is the current topic for me in 2022.10.
508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
today Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
A topic that interests me
pandokrator (7th July, 2015)
i have made same work on vectra (pcf7946 3buttons key)
vaux-com & op-com can program (pre-coded pcf with zedbull) direct on car,Can't program already programming pcf.
tech2 Can program used key (via can bus adapter)
i make key with new pcf and car start but still not work remote
bR
2nd hand keys wont code in , it must be a new remote key unless you cahnge the chips on it and precode them , also as has been said if reading a new virgin remote key in a cloner/reader it often corrupts these so unusable.
estate (7th July, 2015)
Hi all in my neck of the woods we have 2 types Valeo and Siemens. ..they look identical but can't be used on wrong vehicle type ...i have used both dealer key and aftermarket and have never had a problem on either astra j or corsa d ...as others have said maybe key is damaged or wrong type of key was supplied ...regards Irvine
Correction read as astra h regards Irvine
