Results 1 to 13 of 13
    Oct 2011
    Default 1997 MERCEDES C180 DAS 2 CODING...
    Good day members.....i have a 1997 Mercedes C180 that has been towed to my workshop which has a stolen immo box, original ecu and original key...I have bought a immo box from scrap yard , I need to align immo box(OD53J) to key(93c46) and has a 24c04Vdo ecu. The car has a key reader around ignition with green and red lights at rear view mirror system. Could someone please realign attached dumps. Many thanks in advance .
    Bllinda's Avatar
    Baltic
    Default MB'97 C180 das2
    Keys ....
    today
    A topic that interests me
    Oct 2011
    Thanks again Bllinda ....if I write to the 93c46 eeprom on the key will it start the vehicle as the immo box is not from this car? because I do not have star if it needs to be aligned.....Thanks in advance
    Oct 2011
    Correction its a x24c02 eeprom on the vdo ecu
    bram380's Avatar
    Indonesia +628153111774
    Quote Originally Posted by SirshenG View Post
    you need align immo to ecu
    Oct 2011
    Thanks bram Would u have a matched ecu, immo box n key dump for this system?
    bram380's Avatar
    Read eprom ecu,
    i think many DK member will help you.
  8. The Following User Says Thank You to bram380 For This Useful Post:
    SirshenG (22nd July, 2015)
    Oct 2011
    Default Ecu Dump
    The Vdo ecu part number is 022 545 87 32 ...eeprom x24c02 file attached....thanks in advance
  10. #9
    leandroks's Avatar
    Brazil
    E320 GRINGO.rar
    Hi there, i ve got a mercedes w210 e320 wich got the Immo 0d62j corrupted, so i got a immo box from junk and i need to match it to my ECU.
    Could any one give me a hand on that???
    Thanks in advance
    Leo
  11. #10
    bram380's Avatar
    try this dump:
  12. The Following User Says Thank You to bram380 For This Useful Post:
    leandroks (6th August, 2015)
  13. #11
    leandroks's Avatar
    Brazil
    Need to adapt with star:::???
  14. #12
    bram380's Avatar
    Quote Originally Posted by leandroks View Post
    yes, need star das
  15. #13
    leandroks's Avatar
    Brazil
    I ve got another mercedes complete dumps set.
    93c46 from ir key
    0d53j from immo box
    24c02 from ecu
    If i write those dumps is it going to work??
    On the ecu there is another eeprom 27c210 is necessary to write it as well???
    Thanks a lot..
    Leo
