Results 1 to 7 of 7
    Jan 2011
    Default add key to pathfinder bcm
    hi can someone add key to this bcm its a 05 pathfinder can not code key says programmed but still immo light have been trying to activate module on tm100 but fly dont answer i think they have holiday here is the dump and image of bcm
    Bllinda's Avatar
    Baltic
    Repeated ....
    today
    A topic that interests me
    Moderator
    PremierD's Avatar
    Jun 2009
    TM says no keys detected ....
    Jan 2011
    any ideas
    Sent from my GT-I9505 using Tapatalk
    cjawahir's Avatar
    T&T
    read as 16 bit , also show a picture of the ignition antenna ring .
    cj
  6. The Following User Says Thank You to cjawahir For This Useful Post:
    PremierD (6th September, 2015)
    Jan 2011
    solved but strange he found orig key coded it in perfect starts but wont except spare key does anyone know if its precoded or not
    cjawahir's Avatar
    T&T
    Quote Originally Posted by insomnia2009 View Post
    read you key in hitag 2 mode
    cj
