Results 1 to 5 of 5
    Default 2014 suburu xv need help
    friend of mine tried to program second key to the car after that car no start and code is for wrong key and security light is blinking,he used skp900 tool.i got the dump from the body control ecu with the memery 24c02 chip.i have fvdi and zed bull clone I read the keys both tools say key type 4D 60.on key g chip on the shank.
    ist key id read as -DATA 17 08 2E8BA484
    RESP:2C5759 B37D04
    2ND KEY-DATA:17 00 5590B984
    RESP: 2C5759 B37D04
    Please check the dump and help us to solve this problem.can some body with more knowledge and advavce tool add this keys to dump and calculate the pin if they can.
    Jan 2013
    XV use G chip,TANGO can add a key.now you can read 93C56 in the ecu to fix it
    Bllinda's Avatar
    Baltic
    programmer that has already been named the Subaru'12- XV 24.C02,4D.6F) is ....
    .... v1.97
    today
    A topic that interests me
    yes it has 24c02 see the attached dump,how can I add this key data to dump manally
    Will this chip work for a 2014 subaru crossover.
    tnx
    151616853070
    ebay number>
