Page 1 of 2 12 LastLast
Results 1 to 15 of 27
    Sep 2012
    Default skyboxf3 cant get it to work with recover firmware etc
    hi got a skybox f3 it went off and coudlnt get it to work so decided to use the r332 method we the dead box recovery software ....all what happens when i press the next button ,,,,it keeps saying reset stb....ive tried various methods turning box on and pressing the next button ...ive tried and tested the power circuit on another box all good ,,can someone help me identify the chip that has gone down on the mother board ,,,,or tell me were im going wrong with this ive used the recovery .software off here buyt no joy please help bangin me head
    Nov 2012
    sean ive got the same problem mines is stock on lo40 on display took it to a mate its letting him so far then nowt
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by seangraves View Post
    Just to confirm. Are you leaving the box turned off until you see the message "Synchronizing STBs...please reset target!". Once you see this, then you turn on the power to the box.
    Sep 2012
    Quote Originally Posted by Hadron View Post
    SO I PRESS THE NEXT BUTTON WAIT TO SYNCHRONIZING STBS ,,,PLESAE RESET TARGET ,,,THEN TURN THE BOX ON ,,,,
    I TRY THAT MATE,,,,,,IVE READ THAT MUCH STUFF IE TURN BOX ON WEN PRESSING NEXT BUTTON ,,COUNT TO 10 THEN TURN BOX ON ETC THANKS FOR THAT PS ,,,,WHAT FIRMWARE DO I USE TO LOAD ON TO BOX IS IT THE EROM M8 FLASH ,,,,,THANKS
    DK Veteran mahrkpat's Avatar
    Jun 2012
    Try this first from official source: RS232 tool = SBrs232F3-M3.rar firmware=skyboxf3f5m3.rar
    This I think for the a clone maybe?: RS232 tool =F3_LOADER.zip firmware=hdSKYBOX_F3_20130123.zip
    Use the RS232 tool and firmware togather either official or clone, if one them works let us know which one.
  6. The Following 2 Users Say Thank You to mahrkpat For This Useful Post:
    glen321 (16th May, 2013), slugworth (19th May, 2013)
  7. #6
    DK Veteran slugworth's Avatar
    Nov 2011
    new england
    the f3_loader has a button for security core,don't know what that is all about.
    If you don't select a file and hit the flash or core buttons it says can't open prog.dll
    But if you select a file,then it attempts to load. I don't have an f3 so I was just playing with the loader.
  8. #7
    Nov 2011
    new england
    I think the factory did an oops
    The f3_loader.zip has a button to program the security core or flash and was on a factory website along with the other loader.
    Today that file is gone off the site.
  9. #8
    Nov 2011
    new england
    Post
    sc_flash-ok bin is the file to find to be able to program the security core or flash.
  10. The Following User Says Thank You to slugworth For This Useful Post:
    jamest6 (19th May, 2013)
  11. #9
    Nov 2010
    when this happened did u just install the new A Jay channal list?
    i stalled it and have been stuck on load
    have tried with the RS232 and just stays on Synchronizing STBs...please reset target!
    nothing happens any help ?
  12. #10
    Nov 2010
    hi i have done that all day but nothin happens ?
    any help please
  13. #11
    Nov 2010
    i tried both of these with my boxes but no progress unfortuantely
  14. #12
    Jun 2013
    any1 no how to reflash dead skybox f3 and would any1 have the software to do it? cant find a file and 1 file I found just keeps sayin wrong file
  15. #13
    P&D's Avatar
    May 2010
    Quote Originally Posted by bluestaff View Post
    Helps read all the pages (i know 27 of them) but explains all questions
    i have just done one with this tut
    Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
    No good me just linking you to the software then 100 questions afterwards
    everything is in the link you need
    make sure you can get a
    Serial RS232 Null Modem Cable http://www.ebay.co.uk/itm/DB9-RS232-...item232c374c96
    & your computer has a com port
    photo of a com port - Google Search
    or forget it
    which file are you using ????
  16. #14
    P&D's Avatar
    May 2010
    This seems to be happening a lot at the moment....
    PLEASE CHECK MY POST ABOVE YOU NEED THE CORRECT CABLE BEFORE YOU START
    I had a F5 stuck in the loop (load) same as most errors on the openbox & the F series & dreambox i think
    The files you all need are.......this is parts from other posts on DK & other forums so thx to all
    Loader
    Download the file:- "Upgrade_PVR800_HD_Tool.rar if this does not work which it didn't for me you need erom_upgrade_8Mflash.rar at the bottom
    software from skybox.cc unless you have a backup image of your box on usb
    depending on whether your box is a clone or not (this make a big difference) & you will get File mismatch if not the correct file
    Once you have both parts of the software you need .....how to thx to HiTeck
    Open the upgrade tool it will open in WinRAR.
    Extract to your desktop or location of your choice.
    You will now have a folder containing these files.
    With the box turned off at the mains plug the null modem cable into the box and into your pc.
    Run the Loader named EromUpgrade and select browse, pop box will load select the abs file as below.
    Make sure the correct com port is selected.
    Now switch the box on and press NEXT then follow the instructions to load the firmware.
    If the process does not start, try various time combinations of switching the box ON after selecting ***8220;next***8221;
    Don***8217;t switch the power off or disconnect while the download & flash is taking place.
    You can also tick bootloader
    Instead of loading eromceilent.abs load the firmware you have downloaded for skybox.cc
    If you get the message below
    synchonizining STBs
    please reset target!!
    1.not the correct cable
    2.not the correct upgrade tool try the other
    If you get file mismatch then you are using the wrong file download another but try to find out if your box is a clone
    Once you have the firmware loaded hit the next button then plug the power jack into the box (no rush for this part)
    you will see
    synchonizining STBs DONE
    wait a few sec's
    And if all correct you will see a new screen asking you do you want to download file click next
    wait till this is done then the program will ask if you want to (download / Write file) click next at this point most important
    Once done your box will be back to life
    load Aj's channel list & the partwecannottalkabout & chack your settings are correct & you now have a working box.....
    If i have missed anything out i'm sure members will add to this
    Hope this helps P & D
  17. The Following User Says Thank You to P&D For This Useful Post:
    mickmc68 (8th July, 2013)
  18. #15
    Sep 2009
    this will occur when the wrong loader is used. Guide above might be bit long winded but i have recovered a few boxs with finding what works for me from the steps.
    the loader that worked for me was the erom_upgrade_8Mflash.rar and i first managed to get life back into box by loading first the SB.abs file and selecting load bootloader.
    this however only seemed to get box powering back up which was progress from here i then used same recovery method but instead just used loader to install lastest firmware from downlaods and this sorted it for me booted up as normal. one other thing to check is once recovered succesfully check that the DHCP is switched back on had one that had Cline added back in but still never found and connected to server after messing around for a while found it was because DHCP was off so never picked up an ip address.
    hope this helps someone
