still relevant help ....
Hi everybody. We need your help to remove EGR Vw'05 Touran Simos 7.1.
17851-P144-007
EGR potentiometer-G212
16784-P0400-008
Exhaust Gas Recirc. "A" Flow
static
A topic that interests me
What can you recommend ....?
Hm... the first code is incomplete, it is not cool, mate... i spent about 20 minutes to search and cross between decimal and hex VAG codes.
Anyway, here is your file, checksum is fine, probably you'll get a P0000 code, but MIL should be off.
Let me know the result...
Regards!
Bllinda (24th October, 2015)
The client still will return. I write down how I fared. Thx
this flash is a mistake. Does not control this valve ECU.
requires Flash damp comparison. Thank you
does not control valve.
16555 - Fuel Trim; Bank 1: System Too Lean
P0171 - 006 - Short to Plus - Intermittent
vacuum formed fuel tank.
maybe someone can help? I need a flash
The files from the first and sixth posts are the same.
In the first request, you want to erase EGR flow DTC, now you want something else... I don't understand you...
Maybe you can be more specific, explain better the situation...?
mihaiservice (10th November, 2015)
Different problem but same car
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
The client has not yet been checked working "WinOLS (1829.ols (EGR All codes -). bobo.mod".
Called, and said that drives the open fuel tank. because the fuel tank is formed Vacuum.
For that reason, requires original flash compared.
the program can not work as 19 channel vaspc, vas51xx.
perhaps for this reason that vas5054 clone missing IC
So, you don't check if my file work yet and the client told you, that in fuel tank have a vacuum?
Disconnect the EVAP valve electrically and check if still have a vacuum leak trough it. If have - replace it and check the EVAP canister filter.
Bllinda (11th November, 2015)
