Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
  1. #16
    gokey's Avatar
    try zero or O ?
    PUSH reputation and thanks If you think I helped .............................
  2. #17
    Bllinda's Avatar
    Baltic
    Peugeot ....?
    What year of manufacture?
    What motor (letters)?
    read ECU control unit.
    Quote Originally Posted by m-o-y View Post
    Thanks for all
    maybe there is a wrong in this car , because I tried all choices and the result is
    incorrect access code.
    thanks again
    today
    A topic that interests me
  3. #18
    It is 307
    valeo bsi 95160
    ecu mag marelli st10f280
    I tried with zero first and then with o
  4. #19
    Bllinda's Avatar
    Baltic
    ECU label already photo
    today
  5. #20
    Thanks for trying to help
    but car is away , and I reback the component to the car.
    so will upload the ECU photo next time.
    thanks again
  6. #21
    Meat-Head's Avatar
    Leave ignition on for one hour possable security lock out.
    can you share the passsss for that upload on how to read the pin in the hex, how stupid. Goes to the effort of making the folder then just shows one person!
  7. The Following 2 Users Say Thank You to Meat-Head For This Useful Post:
    bangreno (10th November, 2015), super jumbe (10th November, 2015)
  8. #22
    Moderator
    PremierD's Avatar
    Jun 2009
    I thought you knew how to read it ?
  9. The Following User Says Thank You to PremierD For This Useful Post:
  10. #23
    Firstly I thanked wn57 for his files.
    and actually , he only sent me an encrypt and dcrypt dump with normal and swap , and showing the security code.
    but I compared files and extract encrypt codes and what it point in decrypt
    that mean I learned how to decrypt dump manually.
    and will send you codes if you really need it.
  11. The Following User Says Thank You to m-o-y For This Useful Post:
    wn57 (10th November, 2015)
  12. #24
    Meat-Head's Avatar
    Quote Originally Posted by PremierD View Post
    Sort of, understand look in ASCII , byte swap, its the "stand on 1 leg say ff" don't get.
