Does anyone know which relays are for windows?
The car Clio 2001
Thank you very much.
The car Clio 2001
Professional BMW immo solutions
Macedonia is one and GREEK!!!
There is no relay on uch for window , the relay is on electric window motor.
bearheroes (18th November, 2015)
So if windows don't go up or down is not problem of uch?
If not what else could it be?
the window switch have problem.take a schematic on autodata and check
but if you have car test on car with power cable tester on back from relay
I think that will help![]()
A topic that interests me
bearheroes (19th November, 2015), satesquio (14th January, 2016)
Does windows dont work at all, or they cutting?
don't work at all.
I had problem on some clio mk2 windows are cutting, work on moment, than stop...etc
Swaping UCH solve my problems, that was Sagem N1, I put Sgem N2...just to know you can use higher number on lower, but you cant lower on higher...
N3 can replace N2 and N1, N2 can replace N1, and N1 is only for N1, and just swap eeproms desolder his eeprom and solder back to donor UCH.
