any one had problems with the backup of this game not working and freezing.
ok this is how to get it working
start game and let it freeze as normal
copy attached file to SD card
restart Wii go into Data Management and copy saved game from SD card to Wii memory
restart game and select the first profile
>>>> file not available look further down the thread <<<<<
Hi yes i had the same issue, when it said 'create new profile' then it just froze up thanks for that
I seem to be having problems with file, when I put it on my sd card it doesn't show up on my Wii, anyone got any ideas?
Thanks fella, nice easy instructions and game up and running . Any idea how I can stuff the Aussies and make sure they remain at the bottom of the pile for approx 100 years.
is this a european file as i have downloaded ntsc saves and they do not work on my wi
@ doombastik
that's cause you need to make a decent post first and wait for the server to update.
click this link and have a read http://www.digital-kaos.co.uk/forums...ul-tips-30279/
The Falkirk Wheel. The only rotating boat lift of its kind in the world
hi all
im new to this site but am looking to download the save file for my 7 yr old but also looking to help on anything im able to help peeps with
thanx Mel
hello can you send me the save data file for ashes 2009 for the wii thanks
Cheers for this, cant wait to play Ashes. Anybody had similar problems with backup's of Kart Racer or Summer Olympics? For info if it helps I am using a SOFTMOD only console
Replaced faulty wii and had to use the original disk again to create the gamesave. Thanks for pointing in the right direction.
really cant thank you ppl enough..my second day on the site and already 1 or 2 headaches solved... thank you
attached again
if you want to download the game... Get it from
Megashares - Drag. Drop. Yup. The first site to provide FREE file hosting with drag n drop support.
