hello for all i have audi a3
the dashboard is broken
i replace it with other all its ok but i need synchronization ecu to dash
I am surprised that people are afraid of new ideas, I'm afraid the old ideas
Smacks shattered glass, but refine iron.
DO NOT FORGET TO PRESS BUTTON Thanks
you can help .... vas, vc.ds, EG.D2-51.63
A topic that interests me
can i get the pin code
maybe 01087
itll be better if you can read old cluster on bench with programmer then transfer data over to new one, or swap eprom and micronas chips over. the other way is to swap ecu eproms if you have for new ecu with cluster. below is your new cluster detail if it helps
the old cluster is broken I need pin to try adaptation with avdi
golden eagle (22nd November, 2015)
can any one renew the ecu pin not accepted
you can't adapt the ecu on can base protocol only on Kline using channel 50
i use this channel all time i have pin not valide
can get immo number
cs
mac
for write to dasch
hi need flash from ecu,
i get your pin
Original ecu:
immo number:AUX7Z0F9FNO0CS
CS:339E3724673C
MAC:00006C92
PIN:01087
golden eagle (23rd November, 2015)
can any one renew it or immo off
what happend with the old dash?
old dash is broken no have
