Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 76
Thread: Corsa D BCM
  1. #31
    filutek's Avatar
    Silesia
    Pin in eeprom Fx Ex Ex 4x xor in NEC Cx Dx 7x (xor second position refers to the number of second and third)
    FxExEx4x xor CxDxDx7x = 35313634 = 5164 pin says from behind 4615
    BCM logout pin change 3x2x2x8x = FFFFFFFF
  2. The Following 11 Users Say Thank You to filutek For This Useful Post:
    andye26 (25th April, 2016), avital (30th August, 2018), datapage (30th August, 2018), dodor (23rd June, 2018), Faraday (28th January, 2018), Igor64 (23rd May, 2017), plasma533 (22nd April, 2016), racin-snake (7th August, 2018), WISETIGER (4th July, 2016), wojciech300 (1st September, 2017), yellowstilo (30th August, 2018)
  3. #32
    or enter encrypted pin in reverse order into calc & enter xor value in reverse into calc & pin displayed in correct order!
  4. #33
    Jan 2011
    REUNION ISLAND
    hello
    i am trying to read nec 70f3379 with the same pinout but cannot enter bootmode...
    I then tried to connect mcu via spi and soldering 8 cables but get also error "time out pcm0 pin error"
    i AM USING ORANGE 5
    please any help would be appreciated
    Thx
  5. #34
    Jan 2011
    REUNION ISLAND
    i finally manage to read nec with my upa
    could anyone please calculate me pin code.
    thxEXC BCM 93c86.rarEXC BCM nec.zip
  6. #35
    Bllinda's Avatar
    Baltic
    today
    A topic that interests me
  7. The Following 2 Users Say Thank You to Bllinda For This Useful Post:
    plasma533 (6th July, 2016), WISETIGER (4th July, 2016)
  8. #36
    Oct 2016
    What is the address of xor in NEC CF D1 D1 75
  9. #37
    UK East
    surely a simple 'search' for the bytes in your favourite hex editor will locate it?
  10. The Following User Says Thank You to plasma533 For This Useful Post:
    dodor (25th June, 2018)
  11. #38
    Jan 2009
    Any chance to read mcu with JLinkARM segger?
  12. #39
    Oct 2016
    3FD0 – nec address
    Thank you
  13. The Following User Says Thank You to dodor For This Useful Post:
    yellowstilo (28th August, 2018)
  14. #40
    yellowstilo's Avatar
    Quote Originally Posted by dodor View Post
    3FD0 – nec address
    Thank you
    Thank you Dodor , Filutek and others,
    just tested this, use address 3FD0-3FD2 of flash file , double adress 3FD1 > in my example FC 37 18 becomes FC 37 37 18 - then XOR this value with crypted eeprom location 10-13 or 50-53 (in my example CE 0E 0F 28) and you will get the pin code in hex 32 39 38 30 which is 2980 in ascii , read in reverse > 0892 this is your pin..... By the way, IO terminal with Multitool and Opel bsi license will do this in seconds…..
  15. The Following User Says Thank You to yellowstilo For This Useful Post:
  16. #41
    i just wrote this for my own file research but it might be useful for other members :
  17. The Following 5 Users Say Thank You to yellowstilo For This Useful Post:
    antwnhszr (3rd May, 2021), avital (30th August, 2018), conan981 (14th February, 2020), damih (11th June, 2019), datapage (30th August, 2018)
  18. #42
    avital's Avatar
    vagimmocalculator.com
    I move post to main site and create new post with this software link : http://www.digital-kaos.co.uk/forums...e-pincode-calc
    Production and development professional IMMOBILIZER/TCU/ESL/ELV/SRS emulators for all brand cars
    PORSCHE / FERRARI / MASERATI - immobilizer solutions
    VAG IMMO CALCULATOR SOFTWARE
  19. The Following 28 Users Say Thank You to avital For This Useful Post:
    Adi202 (22nd September, 2020), antwnhszr (3rd May, 2021), apavlic008 (7th December, 2021), automotor69 (8th August, 2019), Barajasz207 (13th November, 2019), brend (11th May, 2019), brodaty (6th November, 2018), byyoyo (17th October, 2019), datapage (30th August, 2018), dickymint (21st September, 2018), ekas (20th January, 2023), eleeinidis (16th November, 2018), energologs (25th July, 2023), gobe (26th February, 2021), Hayssam1 (23rd May, 2020), hunterirc (12th August, 2023), jaelgti (20th November, 2018), lake77 (2nd July, 2019), lounadak (12th March, 2020), mosnfet (18th February, 2020), ms8sm (25th May, 2019), nenadgorgi (3rd November, 2018), nesmark (23rd May, 2019), nick_f (20th February, 2020), pit90 (14th April, 2020), qwertyuiop12 (11th May, 2019), rimljan (17th October, 2019), yellowstilo (30th August, 2018)
  20. #43
    thank you very much, just tested your calculator, works 100% !
    you might consider adding the HW Key Number which is visible in ASCII at eeprom address 502-50B (uncrypted) , System Name on address 5634-563A in flash, Software Number on address 563C-5640 in flash and System Description on address 3F8E-3F96 in flash but that info is not really important like your key or pin info.....
    thanks again for your work !
  21. The Following User Says Thank You to yellowstilo For This Useful Post:
  22. #44
    Oct 2017
    Novosibirsk
    Quote Originally Posted by WISETIGER View Post
    Hello! How do you read NEC with UPA?
  23. #45
    Oct 2017
    Novosibirsk
    Can anyone share a script for NEC (UPA USB 1.3)?
