Zgemma
Star H2S HDFreaks 5.3 build-59
only flash if you have a NEW Zgemma H.2S
Build info:
language english
AV 720p
INSTALLED ON THIS BUILD
Plugins:
Cacheflush
EMC git20151003 (setup) DO NOT DELETE THIS BOX WILL NOT BOOT
Media scanner
OpenWebif
Plugin Updater
SoftWare Management
Swap Manager
XMLTV-Importer
Skin:
Slyk 1 HD v1.58
ZGEMMA S2 SETTUP
ADDING A BIGGER USB DRIVE TO THE BOX FOR RECORDING
1st to initialise your drive or AFTER FLASH (make sure zgemma folder is not on usb)
Insert usb in back
Turn on
Menu
Setup
devices
harddisk
Initialisation (select ur usb/
hddlanguage english
AV 720p
Plugins:
Cacheflush
Media scanner
OpenWebif
Plugin Updater
SoftWare Management
Swap Manager
XMLTV-Importer
Skin:
Slyk 1 HD v1.58
ZGEMMA S2 SETTUP
Insert usb in back
Turn on
Menu
Setup
devices
harddisk
Initialise with red button
Now Check
Menu
Setup
devices
harddisk
filesystem check
then
Menu
Setup
devices
harddisk
convert ext3 filesystem to ext4
512MB SWAPFILE SETUP
Menu
plugins
Swap manager
Make sure its created, enable at startup and active- or see setup thread.
everything else should be set to correct paths after reboot.
SCANNING CHANNELS
Menu
setup
service searching
autobouquets maker
providers. Change sky uk: to your area.
save
delete bouquets
start scan
reboot
PICONS
add the picon folder to your HDD
SCREENS
Now Check
Menu
Setup
devices
harddisk
filesystem check
then
Menu
Setup
devices
harddisk
Menu
plugins
Swap manager
SCANNING CHANNELS
Menu
setup
service searching
autobouquets maker
save
delete bouquets
start scan
reboot
PICONS
SCREENS
build update
HDF Build 59
slyk 1 HD V2.0
hi guys i take no credit for this backup as it is not mine
RAR password: qwerty
HDF Build 59
slyk 1 HD V2.0
