Results 1 to 8 of 8
    Member ipsoftw's Avatar
    Apr 2013
    Bulgaria
    Default ECU Mitsubishi 24c04 sync with ETACS cheksum problem
    i don't have mut 3 for now and have a problem with sync i found them with guide made by furnata, but don't know how to correct checksum of entire file.
    My sync code
    D5 9A FF D3 53 03 FB
    and checksum 8bit calculated is
    please help me with calculation of entire file in what format, xor, in ?? some said Custom CRC 32 bit, but i dont have success.
    checksum is located in the end of the file.
    colt 1.3 24cs04 ori.zip
    I'm sorry for my bad English, and sorry if ask a stupid question. I'm newbie and learning with the time.
    Apr 2013
    Bulgaria
    someone to help pls i need to calculate checksum of entire file in Custom CRC 32
    Bllinda's Avatar
    Baltic
    I comes out so ....
    the entire file
    Checksum-8..70
    CRC-32..064A5CDC
    Checksum-8..92
    CRC-32..4957FFFC
    today
    A topic that interests me
  4. The Following User Says Thank You to Bllinda For This Useful Post:
    ipsoftw (27th April, 2016)
    Apr 2013
    Bulgaria
    Tested, car won't start. Furnata was make it one here but nothing for crc on entire file. Its seem to be custom crc 32 with custom poly, but noone know it. I dont know ... i try it all and im end ty for help. ill go find someone with avdi.
    Bllinda's Avatar
    Baltic
    try .... PM
    today
  7. The Following User Says Thank You to Bllinda For This Useful Post:
  8. #6
    Apr 2013
    Bulgaria
    thanks very much for the help, I found 2 paired files of ecu and immo and wrote my existing keys and remote to the file in the immo and the car is ok. starts and unlock fine. if someone need, I found a way to manualy transfer the old keys and remotes to new file. if want, send me old Motorola ETACS file, and will give new file with keys written in it and 24cs04 file for the ecu.
  9. #7
    Lithuania
    Can you help for me with this mitsubishi auto,
    Can you ad me key to you new dump?
    Big thanks.
  10. #8
    Lithuania
    Hi ipsoftw
    Do you have managed my files?
    ps.Clear you PM
