Two codings suggested to you before are not correct because have wrong:
1. G85 sensor type config in byte 4 (depends on the location of G85 sensor that depends on the presense of block 16 and steering column generation)
2. Vacuum sensor type config in byte 15 (depends on the engine type/model)
As your scan contains steering column part which partnumber begins from 1K0, your car is LHD. On RHD it starts from 1K2.
As you got BKC 1.9 engine and steering column gen.3 I guess following coding:
11422012492700FB881404E8922100413000
As I did not see your trunk sticker, hopefully 280mm front + disc 253mm rear break disc config is correct.
Also you did not decode VIN and I do not know if the car has 7K6/7K9 (TPMS) option. If it has it, enable bit 2 in byte 16.
You did not tell anything about presence of ESC/TSC/ASR off button. If the car has it, enable bit 3 in byte 16.
So with TPMS+ESC/ASR off button the coding would be:
11422012492700FB881404E8922100413C00
Beside all this I suggest to update fw of the block onto freely available 1K0907379CD_0120.sgo.
Don't forget to provide the working coding you end up with here & press thanks button.
Good luck!
