Page 91 of 245 FirstFirst ... 41818687888990919293949596101141191 ... LastLast
Results 1,351 to 1,365 of 3668
  1. #1351
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by kazikk View Post
    Can some one help me with codinf for Caddy
    Here you go , one of these Long codes should be your code
    433C400D092703FCC20B02E99020C091310000
    633C600D092703FCC60B06E99020C081300000
    423C400D092703FC420B02E99020C051310000
    if my post was Useful , Press Thanks & Rep Buttons
  2. The Following User Says Thank You to vagva For This Useful Post:
    kazikk (18th September, 2018)
  3. #1352
    kazikk's Avatar
    Quote Originally Posted by vagva View Post
    Need 20 bit coding ;(
  4. #1353
    vagva's Avatar
    Apr 2016
    Hmmm
    its easy friend , just add more 2 digits at the end ( 00 )
  5. #1354
    kazikk's Avatar
    Hmmm
    Not working
    Coding rejected
    error 31:request out of range
  6. #1355
    Jun 2009
    Italy
    hi I need long coding for golf mk6
    here the vin
    WVWZZZ1KZ9P419553
    year 2008
    engine cbd
    kw 81
    2000 tdi
    start and stop no
    manual
  7. #1356
    Nov 2015
    hello friend can you give me a ABS long codding for this vin:wv1zzz2kzcx076061, thank you
  8. #1357
    Oct 2008
    Help with long coding
    Audi a3 2.0tdi
    2008
    Vin : WAUZZZ8P29A029409
    engine : cbba
    MANUALL TRANSMISSION
    ABS 1K0 907 379CD ESP MK60EC1 H35 0120
    rHD
    START/STOP "NO"
  9. #1358
    Bllinda's Avatar
    Baltic
    Read in PM. now there's a mistake abs in the block?
    Not working
    Coding rejected
    ile pozostało blendow?
    today
    A topic that interests me
  10. #1359
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by lorexx View Post
    here the vin
    WVWZZZ1KZ9P419553
    year 2008
    engine cbd
    kw 81
    2000 tdi
    start and stop no
    manual
    Here you go
    one of these should be your long coding :
    113B400D09238003881002E9901C0142350800
    133B200D09230003C81004E9901C0091310000
  11. #1360
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by AMON View Post
    Audi a3 2.0tdi
    2008
    engine : cbba
    rHD
    START/STOP "NO"
    Here you go
    1142401209240003880F02E49022004139080053401
  12. #1361
    Jun 2009
    Italy
    Here you go
    hi I try and both are wrong if I put all I received error 12 if I remove 00 on the end I received error 31
    maybe I must need a code to enable long coding like code for adaptation?
    regards
  13. #1362
    Aug 2015
    you can calculate the coding abs by the VIN
    1VWAT7A36EC031933
    motor CPRA
    ABS 1K0907379BK
    ESP MK60EC1
  14. #1363
    Aug 2015
    1VWAT7A36EC031933
    motor CPRA
    ABS 1K0907379BK
    ESP MK60EC1
  15. #1364
    Hello Please WWWAUZZZ8PCA095106
    THANKS
  16. #1365
    Oct 2008
    Default not working
    different lenght, did not accept
