Page 5 of 16 FirstFirst 1234567891015 ... LastLast
Results 61 to 75 of 237
  1. #61
    Quote Originally Posted by tehnosoftex View Post
    From what I understand from that pdf it must work on any locked 7941.
    no... it can 'unlock' any but that just means erasing it, which would leave it useless without writing a data file like the chrysler file.
  2. #62
    tehnosoftex's Avatar
    Romania
    Quote Originally Posted by paul_12345 View Post
    Yes but then it can be prepared with effi or fvdi for being used with other cars IE astrah.
  3. #63
    yes but the remote wont work.
  4. #64
    Bllinda's Avatar
    Baltic
    Here the file is needed ....
    today
    A topic that interests me
  5. The Following 2 Users Say Thank You to Bllinda For This Useful Post:
    sepistar (2nd November, 2018), tehnosoftex (27th September, 2016)
  6. #65
    Bllinda's Avatar
    Baltic
    I think that really will not work ast.raH remote control
    today
  7. #66
    The same can be said for the original. The quality on the original looks like it was built by the lowest bidder.
  8. #67
    Mar 2016
    South Africa
    hI actionx did it work ok on the nats 5/5.6 ?
  9. #68
    Nov 2012
    Yea the Tm100 info was ripped out of tango. Then they got the soft working. I do not think they cracked the dallas 5003 micro. Did a ghetto in out fix like they did on the avdi. I bought a clone orange 5 because original took a shit. We need put remote data up for all chrysler keys and anything that uses 7941 to make orange immo reset more usefull. Have been logging out put of orange and mk3. Thought about making a device but by time done mk3 clones will be out. tnt enforcer opens up tm100 soft that needs paid for and alot of mk3's software options. Hey why unpack exe go through all the hassle, just run xp and tntenforcer.
  10. The Following User Says Thank You to 912secured For This Useful Post:
    HeXeN (27th October, 2016)
  11. #69
    Quote Originally Posted by 912secured View Post
    I brought a very cheap logic analyzer to log vvdi prog writing to pcf7941 and its very easy to see the data being read - just shows how sh*t orange 5 immo software is not to have added mk3 options.
  12. #70
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    where get this tnt enforcer?
  13. #71
    Jun 2013
    This is one of them.
    http://www.savagecircuits.com/index....logic-analyzer
    From text - scroll down:
    All in all I think the Saleae Logic analyzer is a great diagnostics tool and I would recommend it to both beginners and seasoned engineers. It's inexpensive, portable, reliable and Saleae continues to make improvements to the software. It also carries a 2-year warranty, which is great for a diagnostics tool. In future episodes of Savage Circuits TV we will be covering some examples of debugging and troubleshooting using a logic analyzer and the Saleae unit will be featured in these episodes. If you have any questions or comments please reply below and I will try to pass on any important information to Joe at Saleae. You can order your Saleae Logic Analyzer here.
    https://www.saleae.com/?gclid=CJP_6s...FQHncgod7NwAVQ
    This could be used with remotes, and debugging them for the KD9xx tool or Samic's newest tool?
  14. #72
    Quote Originally Posted by Weasel3 View Post
    I brought the clone version for a few dollars, it would be no good for kiydiy remotes because the data in encrypted.
    it can be used to sniff data to pcf79xx, although it logged the read not too bad but might not be good enough for the write as it didn't seem to log properly, so would need something better probably.
  15. The Following User Says Thank You to paul_12345 For This Useful Post:
    Weasel3 (27th October, 2016)
  16. #73
    Sep 2014
    Tried reading hc05 (x32) on a merc e-class w210.
    Failed!!
    not sure adapter or chip.
  17. #74
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by Zeddy View Post
    Failed!!
    i read HC05x32 with O5 clone success, make picture of your adapter and check soldering points
    when you want to be 100% sure, better to resolder all point on them
    many thanks to friend kevfield
  18. The Following User Says Thank You to daxxer For This Useful Post:
    rokibar (14th November, 2016)
  19. #75
    lidons's Avatar
    Feb 2011
    Quote Originally Posted by daxxer View Post
    I do not think, that this is the problem in welding. I think it is in the voltage, that sometimes it loses, first to make BOOT, and when of OK then to read, if you change manual of a value smaller to 5v to read to 5v down to the right, this error tries, also When you do a bad reading the info of the MCU modifies it to you, be careful to read an original MCU or it will be damaged.
    excuse my English, is the best.
  20. The Following User Says Thank You to lidons For This Useful Post:
    daxxer (15th November, 2016)
