Results 1 to 6 of 6
    Dec 2009
    Default Lexus CT200H Smart Module
    Has anyone got any info as to where the Smart module on a CT200h is located?
    I have one with all keys lost (Proximity)
    Even better if anyone has location images.
    Thanks in advance
    siyadk's Avatar
    Dec 2012
    passenger side.. remove glove box and you will be able to locate it
  3. The Following User Says Thank You to siyadk For This Useful Post:
    gurmk (12th June, 2016)
    Jun 2016
    Dallas, TX
    Hi siyadk,
    would you happen to know where I would find the SMART KEY I.D. CODE BOX? part number is: 89784-76011. I have a 2011 lexus ct 200h base. I did find the SMART KEY ECUart number -89990-76011 behind the glove box. I had a dealer diagnose my car not starting issues and they told me i need to replace both of those modules. any help would be greatly appreciated. any direction towards picture/diagrams would help a tremendous.
    I've taken apart the dash, checked behind the instrument cluster but no luck. I don't see it under the passenger to driver side dash, I've also checked the rear pillars and found the door control module.
    Bllinda's Avatar
    May 2010
    Baltic
    Here you can find ....
    This is the current topic for me in 2022.10.
    508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
    today
    Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
    A topic that interests me
  6. #5
    keysph's Avatar
    Feb 2011
    Smart module is behind glovebox as siyadk said http://www.japan-parts.eu/lexus/us/2...or-lock#89990A see No 1 it is placed in a housing
  7. #6
    siyadk's Avatar
    Dec 2012
    you have to remove whole dashboard out. To be exact it is all the way behind the center A/C duct. once you remove dashboard you could a group of wire going to down towards the metal part of the frame
    since i am guessing you are not locksmith by profession, you might need some tools to this job, like eeprom reader and some obd tools. If you dont have this, there no point in removing the immobilizer
    Whats wrong with car, please explain detail and which region is the car from
