Results 1 to 15 of 15
    HeXeN's Avatar
    Mar 2015
    Default Toyota 4D-67 what Pg1 means & how to precode?
    I have a used key from toyota, dont know what model, effi shows 4D-67, Pg1 56.
    I have new 4D-60 transponder, how to precode it with effi? What Pg1 should I choose? There is no Pg1 56. What Pg1 means in effi image generator? For different model we should choose different Pg1?
    Can 4D-67 be reused on other toyota?
    Jun 2016
    Centurion
    why need precode new transponder when old one can be used again and again and again ?
  3. The Following User Says Thank You to PierreTheron1 For This Useful Post:
    HeXeN (14th June, 2016)
    siyadk's Avatar
    Dec 2012
    first of all page 1 :56 transponder isn't exactly 4d 67 even though many chip reading device says so( for example zedbull clone). it is called G chip
    4d 67 40 bit has page1 number B2,32,52,72 and 92
    G chip 80 bit has page1 :36,56 and 96 Most of the outdated programs shows this as 4d67 since this programmers doesnt have capabilities to read DST+ chips
    you cannot precode 80 bit transponder in effi. At the moment only tango,tmpro2 does
    And yes, you can reuse any toyota transponder as many times as you like
  5. The Following 11 Users Say Thank You to siyadk For This Useful Post:
    airmax (17th June, 2016), autoTkey (15th June, 2016), bonux (29th October, 2020), Fallen (15th June, 2016), HeXeN (14th June, 2016), jurlak1 (27th December, 2021), PierreTheron1 (15th June, 2016), stickmuon (6th July, 2016), stoyanov (15th June, 2016), Tariel (11th July, 2016), ucokseparoh (21st June, 2016)
  6. #4
    Jun 2016
    prekodowanie nigdy nie przyszedł do mnie nie raz pr?bować, inny transponder toyota transponder wszedł OBD, ponieważ istnieje TPX powłoki, EEPROM, Effi pokazuje co jeszcze, co jeszcze tango evo kolejna rzecz, aplikacja może dodać tylko trzeba mieć 30 stare pipsy Toyota, oczof course, it is only after the cableywiście, to tylko po kablu
    Siham's Avatar
    Jul 2014
    Quote Originally Posted by jusefzygo View Post
    Dear Sir jusefzygo only english here please.
    Thank you.
    No thank , no HELP .
  8. The Following User Says Thank You to Siham For This Useful Post:
    super jumbe (4th July, 2016)
  9. #6
    Jun 2016
    I can not speak English , it will shortly be re- old toyota 4d, pg ...
  10. The Following User Says Thank You to jusefzygo For This Useful Post:
    dyzio (15th June, 2016)
  11. #7
    Bllinda's Avatar
    Baltic
    english ....
    A po angelsku, moze ....
    today
    A topic that interests me
  12. The Following 2 Users Say Thank You to Bllinda For This Useful Post:
    dyzio (15th June, 2016), PierreTheron1 (15th June, 2016)
  13. #8
    Oct 2015
    Quote Originally Posted by PierreTheron1 View Post
    can you explain me please how used 4d locked transponder can be used again and again and again...
    thanks in advance
  14. #9
    Jun 2016
    Texas 4d, id 60,63,..70 return, re- work
  15. #10
    Oct 2015
    i am not sure in this...
  16. #11
    Jun 2016
    world
    Quote Originally Posted by rokibar View Post
    thanks in advance
    only CN2 or CN1 can be reused, so you must unlocked it before.
    thks.
  17. The Following User Says Thank You to lioncam For This Useful Post:
    rokibar (15th June, 2016)
  18. #12
    Oct 2015
    Quote Originally Posted by lioncam View Post
    thks.
    talking about original Texas 4d, id 60,63,..70 not about emulators
  19. #13
    siyadk's Avatar
    Dec 2012
    thanks in advance
    no need to anything, you can use toyota transponder over again and again. Lock or unlock doesnt matter
  20. The Following 3 Users Say Thank You to siyadk For This Useful Post:
    HeXeN (18th June, 2016), PierreTheron1 (15th June, 2016), rokibar (15th June, 2016)
  21. #14
    ucokseparoh's Avatar
    Aug 2015
    Indonesia
    Hi guys..
    can anyone give me a hint as to which chip should i get to produce 4D with Tango?
    I've seen some fellows said that the chip i need for it is unlocked blank ID60 chip with pg1:FF (i assume it must be the old 40bit). But have been searching over the net i really couldn't find any sellers who actually sell this chip,only found advertisement yet don't really have it in stock and blank ID60 80bit.
    Can i produce 4D 61-70 with this blank ID60 80bit? If it's not possible which chip should i get as alternative for it?
    And the other thing i'd like to know is about Tango Toyota G image generator for page1 : 36,56,96,37 & 57 (if i remember it correctly).
    I've been playing with my Tango for sometimes with some dumps i got from here and there. Whenever i load a G chip dumps on Tango i always get notification in which saying "Genuine Key Only". My question is : Is that mean by having this soft activated and the chip produced with it means the need for "Genuine Key Only" is no longer necessary? (can be replaced with the chips produced with this soft?
    I really am hoping you guys will help me out with this before i order them.
    Thank you very much for any help.
    Best regards..
  22. #15
    Nov 2017
    sorry-wrong post
