Page 61 of 73 FirstFirst ... 1151565758596061626364656671 ... LastLast
Results 901 to 915 of 1264
Thread: X-Prog M
Hybrid View
    ovi_dk's Avatar
    On board
    Thank u,i make mi x prog back with the dumps wath i put on dk,and all worck greath!
    If u have the answer say Thank You!!
    Bllinda's Avatar
    Baltic
    Question &.08as,az
    I'm out on this connection scheme is not very good at scanning.
    What am I doing wrong that does not scan.
    today
    A topic that interests me
    dimitar's Avatar
    Quote Originally Posted by Bllinda View Post
    This connection is for xprog not xprogm
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    kautuvera's Avatar
    Quote Originally Posted by dimitar View Post
    It is possible but there is a problem
    http://www.digital-kaos.co.uk/forums...0/#post1528162
    dimitar's Avatar
    Quote Originally Posted by kautuvera View Post
    of course you need the correct security bytes.
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    Bllinda's Avatar
    Baltic
    Question !.-m
    One of these connectors will be good?
    today
    Apr 2012
    I think the company you mean is autobink.com
    Anyone know if you can buy the eeprom adapter board seprately from anywhere?
    Hello mates, my xprog-m was working good for 6 month, now it is seen by program, but when I want to read something, it shows- Initialising Hardware: DEVICE IS SILENT
    May 2012
    brasil
    Quote Originally Posted by napel View Post
    estou com o mesmo problema vc ja resolveu?
    me ajuda
    Jun 2009
    check if you connect the usb cable in software you can seen the port that is connected.
    press to read a memory and notice if the green lamp is open . if not you must cahnge the usb cable or port of computer.
    if you see the green lamp measure if the 5v is always on in the adaptors if yes you have a burn mosfet 8pin in your hardware. i have repair a lot of times my clone xprog
    hello all any one have test new xprog V5.3 with dongle?
  13. #13
    Lithuania
    Quote Originally Posted by motorsport View Post
    All about Xprog you can find here
    And no any new Xprog with dongle or without New Xprog box only!
  14. #14
    ahadi's Avatar
    hello all
    Does any body has schematics TMS374 on board adapter . I have two but both not good .
  15. #15
    cp2010's Avatar
    Feb 2011
    DE
    KESS 5.028/5.030 VR - KTAG 8.000 EU PCB
    PCMFlash 1.2.0 dongle EU
    STool/MTool v1.49 EU
    ECU Flasher activation
  16. The Following User Says Thank You to cp2010 For This Useful Post:
    jaytool (1st October, 2013)
