is here .... ....
is here .... ....
A topic that interests me
I already tried this one few days ago and doesn't start at all . Problem is that car cuts off and doesn't start few minutes and after scan there is no any fault code found also if I disconnect any plug there is no fault also . so flash I think was very mod somewhere . because dpf plug also I found disconnected. here is file from car I have. maybe someone could check it for me ? o have original flash file of this one ?
see this
pike (29th August, 2016)
same not working
In your case we must going step by step.
I will post your file with restored DTC , so you must flash my file , then you scan for errors , make print screen of errors , delete errors , start car drive little and scan again and print screen.
After that post your print screen to delete just errors what need to be deleted.
Your file >
WinOLS (Opel Vectra-C (errors restored) - 370821).rar
pike (29th August, 2016), vlaki electric (27th August, 2016)
I tried today and car didn't start with this flash . I tried about 5 different flashs and same . only starts with flash which I posted here . I am confused now .
What tool you use for read/write ?
I use mpps and kess also I have galetto 54 and ktag for scan I use op com .
yes I thought maybe some of my tool do not write correctly but for opel I use mpps about 3 years and never had problem with it . I tried kess but same result . one thing is strange that ecu is already was opened is it possible that somehow it was changed from other car and somehow mpps do not recognize correct flash inside ecu . i want to say that tflash number is stored in mpc but actual flash is different inside ecu . because i don't what else to think . first something very strange in my practice that i cant finger out .
Oh Ok.Write back your file and try to start your car. If car start read ECU with BDM and post file.
this is full bdm my friend
hbalazs (20th September, 2020)
Did you try write my file with bdm ?
here you go mate, 2 other files ori
Opel 1,9 CDTI 0281 011 449_370821.rar
Opel_signum_1.9CDTI_150HP_0281011449_1037370821.zip
you can?t handle a car like humans ...a car needs love
