I’ve done a 2017 key the remote section took some time in getting it wright.
Any tips? I'll be using a non-remote head key.
Hi, ray-ray
Do you have any idea how to programming smart key function with this car?
I programmed immobilizer function with Autopropad .
but there no smart key or remote function option on Autopropad.
manual on board programming for that part
its non diagnostic
Driver's door open, all other doors closed, key removed from ignition
switch.
Within 5 seconds:
Insert and remove the key from the ignition switch twice.
2. Within 40 seconds:
Close and open driver's door twice.
Insert and remove the key from the ignition switch.
3. Within 40 seconds:
Insert the key into the ignition switch and close the driver's door.
4. Switch ignition ON and OFF:
A. Once to program a key remote transmitter code whilst retaining the
original codes.
B. Twice to program a key remote transmitter code whilst erasing the
original codes.
C. Three times to check how many key remote transmitters are currently
registered.
D. Five times to erase all registered codes.
5. Remove key from ignition switch. System should now lock and
unlock vehicle
once, twice or five times depending which mode has been
selected. One to four
times, slowly, to indicate number of key remote transmitters
registered.
6. Within 40 seconds:
Press and hold LOCK and UNLOCK buttons simultaneously for
1.5 seconds.
Within 3 seconds: Press any key remote transmitter button.
System should now lock and unlock vehicle once to confirm
registration or twice
to indicate registration has failed.
7. Within 40 seconds:
To program additional remotes repeat step 60 now on each
additional
remote you want programmed.
8. To exit programming mode open driver's door or insert key into
ignition.
9. Step out of car with remote(s) in hand and test remote(s).
The thanks button is HERE looks like this --->>>
THANKS
kitten13 (18th December, 2018), VictorVonDoom (13th December, 2018)
On board programming is not working. Because Smart Entry function!
its straight from the advanced diagnostics manual
THANKS
So if no support by AD company that been working on immo. For 20yrs. It not going to be a available on any tool. Dealer required one working key to register a second Proxy.
really..........
you have a smart entry ls430 right?
they are just saying there is no procedure on the machine that will do it and they dont support it because the machine is not doing it YOU ARE
IT IS AN ON BOARD PROCEDURE
look here read what it says
it says it is provided as a courtesy but it is not supported by tech support since AGAIN their machine does not do anything IT IS YOU DOING IT ON BOARD.
did you try it ?
do you even have the right key?
did you read the car to see if their are any trouble codes?
cmon man give us some info here
but this literally says the machine doesnt do it
do it yourself by OBP
so wheres the problem here?
THANKS
read this part too if it helps
Attachment 576032
Note: Only the immobilizer can be programmed with the PRO. Use on board programming to program the PROX!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
so again what part of this is escaping your grasp?
if you tried and it didnt work
you probably didnt do it right?????
THANKS
I done by OBP. I'm stock at #6 this part (twice to indicate registration has failed)
I purchased new twist smart entry key from Lexus dealer by the VIN.
I scanned with AVDI to pull up DTC. Save and cleared DTC, before program processor begin.
There is nothing special DTC with immo and smart enrty system (A/C, Suspension...)
Reason for I ask ray-ray, He has same post I have questions.
Refer: http://www.digital-kaos.co.uk/forums...ht=ls430+twist
If OBP only the correct procedure for those year car then I assume this car has problem.
Anyway thanks for your help sleepyrz !
All key lost situation.
I have programmed key only insert ignition slut to start.
This car has two function.
One function is insert key ignition slut to start the car, when smart key button battery died.
Second is without pull out smart key just press door handle button to open door and twist knob to start the car.
Just like newest Lexus smart key functions, only difference is twist knob and push start button.
Dear ray-ray,
Do you solve the problem previous job ?
Please refer your past post:
Let me know...
Thank you
