E P G (PROGRAM GUIDE)
  • Geoffers22
    • Aug 2015
    • 13
    Can any one help please?, I have a openbox vs8 the epg is to say the least alful is there a way to set it up so its just like any other epg ?? Look forward to hearing from you
  • androidtvuk
    • Oct 2016
    • 9
    which are you using the satellite downloaded epg or the internet downloaded one XMLTV? Which ever you are using try the alternative in the settings, I prefer XMLTV personally.
    • Geoffers22
      • Aug 2015
      • 13
      its the default that comes with the openbox vs8 I have not changed anything
      • androidtvuk
        • Oct 2016
        • 9
        try the XMLTV see if that suits you better
        • Geoffers22
          • Aug 2015
          • 13
          Thanks for your reply fairly new to this ,how would I do that please
          • androidtvuk
            • Oct 2016
            • 9
            I don't have a box in front of me set up at the moment as I'm playing about with an old dreambox 500, hopefully someone else can check, but it's not difficult, go into settings and look about.
            • Hadron
              • Nov 2012
              • 2102
              I don't have my Openbox connected at the moment either, but found these instructions on my hard drive:-
              Insert a memory stick into your skybox
              1. Press Menu on Skybox Remote control
              2. Press the right arrow button until you see System Setup
              3. Press OK
              4. Press down arrow to highlight EPG and Time Setting
              5. Press OK
              6. With EPG Default Setting highlighted it should say Satellite
              7. Press right arrow once and it should change to Internet(XMLTV)
              8. Press Down arrow to XMLTV Setting
              9. Press OK
              10. Press right arrow to turn ON auto update on United Kingdom
              11. Press RED button update
              12. After about 2 minute the percentage bar will be 100% (Update Success, ALL Finished!)depending on your internet connection
              13. Now Keep Pressing exit until you return to TV programme
              *EPG WILL AUTO UPDATE WHEN SKYBOX IS TURNED OFF
              NOTE: MEMORY STICK NEEDS TO BE CONNECTED ALL THE TIME FOR 7 DAY EPG TO WORK
              • Geoffers22
                • Aug 2015
                • 13
                Thank you will let you know how it goes
                • Geoffers22
                  • Aug 2015
                  • 13
                  Well all was going great till I got a message EPG compression failed not enough free storage space. I am using a usb stick with 128 gb of free space, any idea how to fix this issue please
                  • Hadron
                    • Nov 2012
                    • 2102
                    Does your box have the latest firmware?
                    This error affected a lot of boxes with older firmware. Have a look here for latest firmware:-
                    • Geoffers22
                      • Aug 2015
                      • 13
                      a BIG THANK YOU did the upgrade all sorted
                      • arm74
                        • May 2016
                        • 24
                        Thank you, after the upgrade it's working fine
                        • jc69817
                          • 138
                          Hi guys. If I update my image will i need to reinstall my line or will it be ok ?
                          Thanks in advance
                          • misterminibus
                            • Oct 2010
                            • 9
                            I have been trying all day to update a skybox f3 to do this but number 4 on your list epg and time settings is only time settings. I am thinking my 2013 firmware may be the reason but the official skybox site doesnt list firmware past this date, any ideas?
                            A wise old owl lived in an oak.
                            The more he saw the less he spoke.
                            The less he spoke the more he heard.
                            Why can't we all be like that wise old bird?
                            • P&D
                              • May 2010
                              • 2684
                              #15
                              You can't with the F3
