Any one got any ideas on this? Corsa D 2007 lost keys. I have correct pin code 5234 but the BCM is not accepting the code when i try to program the new keys. Car had a flat battery when i got to it. 93c86 dump is a attached corsa d pg.rar
also need nec dump for pin as well.. 93c86 is only one half of solution
Cromwe11 (11th February, 2017)
corsa d on this model also suffers BCM corruption after a flat battery especially if jump leads used . common issue on these after flat battery , some data gets corrupted in bcm. tech 2 needed to rewrite bcm if this .
I think they advise to update BCM software first before carrying out a reprogram of the BCM
If you have old op-com your BCM will accept security code then reset wait 10 min and should work have same issue Beafore and works
Sent from my SM-G935F using Tapatalk
Follow this procedure from a member.
http://www.digital-kaos.co.uk/forums...a+flat+battery
This is the current topic for me in 2022.10.
508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
today Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
A topic that interests me
Friend I had that problem one month ago, but my car was not losted key situation, I succes to eneter pin code while car was running, not just with ignittion on...maybe you can handle with this if you connect your battery to some car whille running, that will make good conditions for bcm...good luck
Tryed following the procedures. But still no joy if I try to reset the bcm I still get the pin rejected (every other module accepts the pin) both Avdi and op-com show as security wait time active 10mins. But it has been left for hours ignition on with a BSU and no change. I have access to all other modules on the car
