Results 1 to 15 of 21
    Timisoara
    Default Opel Vectra C punp eep corrupted
    Hello
    I have a PSG 16 fuel pump and in the attached file is the info carprog read from it signum.rar
    At 0x820 should be the pin but 00 00 0C A6.
    the only way wold be BDM
    and security wait time is 21:20:00 and of course not changing
    thank you
    kiszka's Avatar
    UK East
    As far as I'm aware PSG16 pumps are coded, as they need to be cleared before being able to be used on another vehicle..
    ps. should be at 840 not 820... it reads 0 0 0 0
    CarProg software for Opel VP44 PSG16 diesel pump electronic programming. Works by OBDII or wired on table.
    Software Functions : Read PIN,Reset ECU, Change Mileage,Change VIN
    Timisoara
    Quote Originally Posted by kiszka View Post
    in the pump there is no pin
    turn on the ignition for 22 hours
    after 22 hours test save pin
    the trick with 22 h was done and the counter remain at the same time 21:20:00
    and after when i try to reset pump the error incorrect pin was entered is active, but can be deleted
    in the mean time i do an SPS update by changing the VIN and after change back to ori VIN,
    now permanent error -> invalid transponder is stored but pump cannot be reset and do not accept programming new pin
    This is right because immo area is not programed or at leas this part
    The problem is in my opinion that there is value stored at 0x820 even if it is part of the pin 00 00 0C A6 and sw routine find a value different that 00 and expect that value as an old pin, just an opinion please correct if I'm wrong
    Timisoara
    Quote Originally Posted by plasma533 View Post
    Yes coded and before adapt to other car ori pin must be entered and after reset function
    After program new pin and adapt pump to imo (CIM in may case) by programming from CIM (CIM and ECM installed)
    But if pin is not accepted in the pump no programming
    The only problem is that pump is the ori pump of the car and the owner start "playing" with op-com and this is the result -> Pump waiting time and no pin at 0x820 were pin is stored.
    Maybe battery get drained and this resulted in pin area data corruption because he try do mod when battery level was not ok. The last digit from the car pin is 6 and the value at 0x820 is 00 00 0C A6.
    Dumps taken from DK
    PIN 2106 and 8701
    http://www.codecard.lt/carprog/softw.../prod_375.html
    UK East
    You have this slightly wrong mate. It looks like there are a couple of different types of eprom for the PSG16s, One with the code at 840 (in a dump which I will attach) and also at 820.. Your assumption of bits of your code remaining are wrong though. If you look at the example from codecard you pasted above yourself you will see that at 800 there is your 00 00 0C A6 and again I repeat this is NOT where the code is stored, its stored two lines below it..
    PSG16.rar
  7. The Following 2 Users Say Thank You to plasma533 For This Useful Post:
    clauberty (28th February, 2017), line44 (13th September, 2022)
    Timisoara
    Thank you for the eye opening info
    After i replace immo MCU in the CIM reset CIM and readapt to car (configuration, key, coding) in the engine ecu wrong transponder key error is stored
    so i'm stuck with the 21:20:00 waiting time? i try to reset pump with carprog and waiting time is still the same
    This time must be passed with ignition ON or OFF? I think should be ON
    UK East
    ignition on mate... if you turn ignition off then you have to start the time again.!
  10. The Following User Says Thank You to plasma533 For This Useful Post:
  11. #9
    Bllinda's Avatar
    Baltic
    I'm thinking that it must be ....
    today
    A topic that interests me
  12. The Following 2 Users Say Thank You to Bllinda For This Useful Post:
    clauberty (2nd March, 2017), plasma533 (28th February, 2017)
  13. #10
    UK East
    also NEVER reset both ECU and CIM at the same time as the key will be lost!
    Only reset engine ECM if changing the pump..
  14. The Following User Says Thank You to plasma533 For This Useful Post:
  15. #11
    Bllinda's Avatar
    Baltic
    The first one of several modules, and only later on the other.
    Or is it depends on where the data is required....
    today
  16. #12
    kiszka's Avatar
  17. The Following User Says Thank You to kiszka For This Useful Post:
  18. #13
    UK East
    no, disconnecting battery will do nothing, lock time will still be there.. ignition must be on for the time period required for it to expire...
  19. The Following User Says Thank You to plasma533 For This Useful Post:
  20. #14
    Timisoara
    Opel vectra.rar
    In attachment are print screens of the errors
    waiting time after 30 h with ignition on is still the same, 70Amp charger is attached to battery / car so no problem of power. I try with pin 0000 -> wrong pin
    car with lock is displayed on the little display from cluster -> i think this info come from engine ecu where wrong transponder error is active
    only cim PCB is mounted this is the reason for all the errors
  21. #15
    Timisoara
    It is Time Lock active and will not allow save pin, will not allow do the reset, will not allow teach immo, Time Lock must disappear in some way or another
    test can to help, disconnect the battery on 30 minutes
    Please explain this "test can to help"
