Results 1 to 15 of 15
    sasy90's Avatar
    Italy
    Default Audi Q7 need pin code
    Hi to all,
    i've a audi q7 2007 year with all key lost.
    I bought 2 new keys on dealer and now i want to adapt that .
    I have a VAS and i try to put 36953 as pincode into "autorization to access" in EZS but VAS say me: " it has not possible to login"
    Someone can help me to determinate correct pincode? In attachment i read 95320 of ecu diesel.
    Someone can help me to tell me the procedure to adapt that new keys?
    Thanks in advance
    Attachment 437158
    To me its the right PIN
    36953
  3. The Following User Says Thank You to eltiobarbas For This Useful Post:
    sasy90 (21st March, 2017)
    sasy90's Avatar
    Italy
    Ok pin is ok. How can i adapt new key with ODIS? I lost all key and now i have 2 new keys to adapt... whats procedure with ODIS?
    rdu04's Avatar
    RO
    in my abritus clone pin is 36953
  6. The Following User Says Thank You to rdu04 For This Useful Post:
    sasy90's Avatar
    Italy
    procedure for adapt key with ODIS?
  8. #6
    sasy90's Avatar
    Italy
    someone can help me please??
  9. #7
    With ODIS only online with GEKO access...
  10. #8
    sasy90's Avatar
    Italy
    ok i found a person that give me GEKO account ... but so my situation is all key lost and when i try to mach new 2 keys , say me "turn ignition on"... How can i do that?
  11. #9
    New keys need to be prepared for vehicle you are adopting to.....
    Wackeup is done with brake pedal depressed and high beam flashing (with lever on steering).
  12. #10
    Oct 2015
    Quote Originally Posted by sasy90 View Post
    Short the two fuses down from fuse 7 and fuse 11
  13. #11
    sasy90's Avatar
    Italy
    i already shorted fuses but don't work... instrument not on....
    With this short fuses , i can diag with odis... but instrument not work
  14. #12
    gepakg's Avatar
    Serbia
    you must have prepare keys with 12 byte CS before programming...
    regards Gepa
  15. #13
    Bllinda's Avatar
    Baltic
    gepakg
    you think of 12 bytes .... Thx
    today
    A topic that interests me
  16. #14
    Sep 2016
    Canada
    Use force ignition on tool
    And you need to precode dealer Key first using CS
    And then learn Keys with that pin
    Sent from my SM-G935W8 using Tapatalk
  17. #15
    Jan 2013
    Don't worry about the cluster not powering up ...immo is in kessy not cluster .when you prepare dealer key and add to kessy cluster will power up. Good luck
