Results 1 to 15 of 15
    Jul 2013
    Scotland. UK
    Default Vauxhall key number Z0579 - need bitting
    Don't have instacode to hand right now, can someone post the cuts for Opel/Vauxhall Z0579 for me.
    Will add thanks and rep to each poster. thanks
    Dec 2010
    Nottingham
    23234211 is bitting for Z0579
  3. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    instakeys (3rd April, 2017)
    Jul 2013
    Scotland. UK
    Nice one rapid, bitting was bang on.
    Doesn't do ignition though, but this is the cars fault...
    Feb 2017
    UK
    Hi my instacode can't find the citroen C1 key code B3535 what il be the bitting for it please
    Dec 2010
    Nottingham
    instacode list the B series codes , you need to search under VA2 rather than make and model , under make and model it doesnt list the B codes , so in future on instacode just search silca va2 and it will be in list for you .
    direct cuts for B3535 are "337HQ4" or search by instacode card 1126
  7. The Following 3 Users Say Thank You to rapidlocksmiths For This Useful Post:
    just4upal (11th May, 2017), p1et (10th May, 2017), redliner (11th May, 2017)
  8. #6
    Feb 2017
    UK
    Hi Thank you I check on instacode now and all good but didn't realize that Va2 can be different I have another problem as my cutting machine can input ABCDEF only.
  9. #7
    Dec 2010
    Nottingham
    what cutting machine do you have ?
    look in citroen menu for 1234Q5678H series and also in toyota aygo menu and also smart key menu , also worth looking in renault clio 3 menu , may be hidden in one of these .
    i know silca and keyline machines have this , miracle A6 and A9 have it , even condor has it in its menu system , can you search by instacode card on your machine ?
  10. #8
    Bllinda's Avatar
    Baltic
    I had not found a way b.35.35.Thx
    Quote Originally Posted by rapidlocksmiths View Post
    What are you working machine tools? What you use for work. Thx
    today
    A topic that interests me
  11. #9
    Dec 2010
    Nottingham
    i have silca viper , keyline ninja , miracle A6 and condor machines and all have this series on them .
    if you have an up to date instacode then you can reach code B3535 , by selecting either instacode card 1126 . or by selecting silca va2
  12. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    Bllinda (11th May, 2017)
  13. #10
    Feb 2017
    UK
    I use KCM7 at the moment. I find this options on Renault and Toyota. I did't know what to look for and this is 1234Q5678H I just wonder how KCM7 will cut this, I hope it can do properly. Thank You so much for your help. Thanks and Rep.
  14. #11
    Dec 2010
    Nottingham
    pleasure , worst scenario is to get a local locksmith to cut key for you , or order it precut from your supplier .
  15. #12
    Feb 2017
    UK
    The blade was cut fine, happy with result THX
  16. #13
    Feb 2017
    UK
    Could you help me to get direct code for Citroen C2 key code is NL1HABADEA and my instacode showing ?????? if I put last 6 letter from code then I get AEDABA not sure if it's right code - is it from backward ?
  17. #14
    Dec 2010
    Nottingham
    yes reverse the last 6 , so AEDABA
  18. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    redliner (20th June, 2017)
  19. #15
    Feb 2017
    UK
    As easy as pie Cheers
