Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 51
  1. #31
    Newbie golf1gti's Avatar
    Nov 2009
    Quote Originally Posted by cammy25 View Post
    Unfortunately you dont live in the neighbourhood
    I have a reel of 1400 pieces of those things here
    if you need any answers about Diga software or hardware just ask.
    Hello samy25
    i hope you can help
    i have tacho 2008 first problem is the touchkeys are broke.
    second problem is normal when you start up the handheld you heard a clivk(relay or somthing inside).
    now when you startup i don't heard the click anymore
    and also when i want to program dash from peugeot206 (you heard normal also same click when programming dash) its do nothing.
    i can program other cars like vw opel.
    thanks alot
    stefan
    the netherlands
  2. #32
    Jul 2009
    Try to resolder all solder joints (soldeerpunten) near the relay on you motherboard.
    Or your relay stay hanging on NC.
    Sometimes the relay will click if you slam your diga with your hand (no joke).
    This problem is called: Chinese shitty soldering techniques.
  3. #33
    Top Poster Maxpower50's Avatar
    Sep 2009
    Default Tachopro repair
    [QUOTE = mikac; 323752] Ja. Jeg ?nsker ? f? h?ndboken for ? reparere tachosoft.
    (fra Maxpower50)
    Takk [/ quote]
    Her er den igjen lykke til
  4. #34
    Moderator
    krazylegz's Avatar
    Mar 2008
    Crowthorne / Sunny South Shields
    use english please
    PS3= krazylegz120282
  5. #35
    Newbie mikac's Avatar
    Subotica
    Thank's to Maxpower50.. but unfortunatly I can not download from forum. I upload all my details , and still can't download. anyway Thank you Maxpowe50 !!
  6. #36
    Subotica
    Smile
    Hey. I just menage to download pdf file , and it will be at help to me. Thank's a lot.
  7. #37
    Aug 2009
    I need your urgent help. It seems that I have a problem with diga consult main unit. When I connect the power cable I can hear the little tick from the relay and the screen has a light but nothing is displayed. What can I do? Thank you.
    Master Computer Engineer, A+, Network+, MCP 4/2k/2k3, MCSA/MCSE 2k/2k3, MCTS, MCITP Enterprise Administrator, Microsoft Certified Trainer/Systems Engineer, Brainbench, ICDL and starting Ph.D.
  8. #38
    Aug 2009
    I need your urgent help. It seems that I have a problem with diga consult main unit. When I connect the power cable I can hear the little tick from the relay and the screen has a light but nothing is displayed. It's brand new from China and never used!!!. What can I do? Thank you.
  9. #39
    melcool's Avatar
    Nov 2009
    SPACE
    Quote Originally Posted by golf1gti View Post
    i read that you have 1400 pieces maby you vcan help me on a problem.
    first my touchpanel is broken.
    also i have a problem normal when you startup the tacho 2008 you heard a click inside (relay or somthing)now when you startup you don't heard the click anymore and ican't do also the dash from peugeot 206(you heard also the klick when you program the dash)
    i hope you can help me
    stefan
    the netherlands
    The relay on the motherboard has bad soldering! strengthens soldering on the relay! I had the same problem
  10. #40
    Nov 2009
    you're right cammy25
  11. #41
    Rito's Avatar
    Jan 2010
    Quote Originally Posted by pawlenko View Post
    HI
    i have big problem with my tacho universal version 2008
    it's never show old km when i'm using 93cxx adapter
    in hex editor only 0000
    but
    i push adjust km it change km ok
    with 24c and another adapter is ok
    I have same problem, But I never has successful change
    I have tried in renault megane 2003 (93c56)
    What I can do for correct this??
  12. #42
    drpeter's Avatar
    Dec 2009
    The Netherlands
    Quote Originally Posted by lupu_sandu View Post
    Cable is OK, i tested.
    I have change 74HC5410 below display (near NEC processor). Same shit.
    Ideea is after changing mainboard it's OK. I guess that CPU board is ok.
    If OBD2 is not working, the small SMD power transistor is defect, left under lCD screen (I think it was a NPN transistor, check number) I took a normal BD137 for this, not sure long time ago. Measure between 2 legs, if shortcut then transistor defect. If not replace the 74HC04D above the transistor. Once I had a transistor defect and on another diga the 74HC04D.
  13. #43
    Rito's Avatar
    Jan 2010
    I wold like know If some people can help how I can put 93Cxx works great.
    My Diga (clone) never read 93Cxx and I see in this web site If change one chip can read and write, only 24cxx...
    Repair and Update KIT for Tacho Universal / Diga Consult
    Some people do it or this not work??
    Or exist other solution?
    Thanks all
  14. #44
    DK Veteran rsibiza's Avatar
    Quote Originally Posted by Rito View Post
    Thanks all
    Hi m8.
    Could you please be more clear? You wanna write 93xx?
    What dash? Make car?year?
    Do the manual show that diga should show old km? If yes,and diga does not show actual value,dont touch.
    Diga shows old value,change.
    Regards.
  15. #45
    Rito's Avatar
    Jan 2010
    For example in renault clio or megane my diga says: (general faul read)
    I can?t read any 93Cxx of course can?t write.
    I see in this web site which have solution for this problem.
    You understand?
