Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Aug 2008
    Norn Iron
    Question open media - non-FTA channels
    hi,
    what do I need to add to OM box to be able to pick up channels other than FTA channels?
    please break it down for me like i'm a 5 year old as I have little technical knowledge
    any help much appreciated!
    Administrator
    Devilfish's Avatar
    Feb 2008
    Download this file...
    RapidShare: Easy Filehosting
    You will need to FTP to your box to be able to transfer files to it. For this you will need an FTP Program and a crossover ethernet cable. It's best if you can connect the box to your router as it's easier that way.
    There's a guide here...
    Dreambox Guides, Tutorials, Tips and Hints Blog Archive How to Connect your Dreambox to your PC
    In the files that you downloaded, copy the contents of the keys folder to the /var/keys folder on your box. Copy the contents of the scce folder to the /var/scce folder on your box. Go to sky sports 1 and hold down the INFO button until the EMU manager comes up, press OK and it will restart the EMU. Wait and the channel should come on...that's it.
    Aug 2008
    Norn Iron
    Quote Originally Posted by Devilfish View Post
    thanks devilfish
    re crossover cables, is there a specific type needed?! best to order online or can they be bought in Currys or Dixons? hoping to buy one 2moro, sunday
    V.I.P. Member Curious123's Avatar
    Apr 2008
    Currys and Dixon won't have a crossover cable but you might have more luck at your loacal Maplins store.
    Aug 2008
    Norn Iron
    Quote Originally Posted by Curious123 View Post
    Thanks. Got cable and files ftpd
    Can't get channels through though. How long should I hold down info button? What should I see?
    Administrator
    Devilfish's Avatar
    Feb 2008
    It only takes a few seconds. If you've transferred the keys and scce files to the respective folders then you can also go to sky sports 1 then reboot the box using the shutdown menu, this will also restart the emu when it reboots.
    Aug 2008
    Norn Iron
    didn't work. Is there a keys and a varkeys folder? Files must have gone to wrong folder
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by qwertyballs View Post
    open the var folder
    inside there will be the keys folder.
    and a scce folder
    put the keys in keys
    and the scce in scce folder
    just replace the folders with the ones your transfering.
    Aug 2008
    Norn Iron
    Quote Originally Posted by aftermath View Post
    open the var folder
    and a scce folder
    Pretty sure that's what we did
    Appreciate the help guys
    Administrator
    Devilfish's Avatar
    Feb 2008
    Copy the files over, go to sky sports 1 and reboot the box from the shutdown menu (Menu > Shutdown > reboot now)
  11. #11
    Apr 2008
    If I remember correctly you dont have cable and only the free sky channels.
    if this is the case then you need to do a search on google for "cccam pay server"
  12. #12
    Aug 2008
    Norn Iron
    Quote Originally Posted by max_gee View Post
    hi Max. What's that server do?
  13. #13
    Moderator
    krazylegz's Avatar
    Mar 2008
    Crowthorne / Sunny South Shields
    if max is correct and you dont have cable but have a sky feed coming into the house, but you currently dont pay for skys services then you will have to do as max suggests.
    we dont allow cardshare talk on here so you will have to google for more specific info, but basicly you pay a small amount to someone elses card with the keys being sent via the internet, your box needs to be connected to the net 24/7.
    PS3= krazylegz120282
  14. #14
    Aug 2008
    Norn Iron
    Quote Originally Posted by krazylegz View Post
    I have just had sky installed. Will wait to card is activated and try open media again
    <--qwertyballs added 4 Minutes and 38 Seconds later...-->
    if max is correct and you dont have cable but have a sky feed coming into the house, but you currently dont pay for skys services then you will have to do as max.
    I have just had sky installed. Should I retry OM once card is activated?
    Last edited by qwertyballs; 25th August, 2008 at 12:05 PM. Reason: Automerged Doublepost
  15. #15
    Administrator
    Devilfish's Avatar
    Feb 2008
    The keys in the cable sections won't work with sky.
    Would have been good if you said you were working with sky from the start.
