Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 71
Thread: tricks and tips
  1. #31
    west mids, uk
    Default known faults and fixes
    Right guys, Im not sure if you check members profiles, but if you check mine you will see what my main job is.
    I have one massive database of common faults and fixes, dating back to the seventies up to present day.
    Not everthing is on there, but me and my 3000+ collueges strive to find faults and fixes/by-passes every hour of every day.
    SO, if all else fails JUST AASK!!!!!!
    I couldnt possibly add it all on here, it would take a lifetime.
    regards,
    the ninja
    ps, send a pm so I know some info is needed, cant get on here all the time.
  2. The Following User Says Thank You to ninja123 For This Useful Post:
    GV Electronics (30th January, 2017)
  3. #32
    DK Veteran BeianM's Avatar
    Dorset UK
    Default Range Rover p38 no hevac display radio cig lighter etc
    Becm fault, no power from relay 7 fed by fuse 8. this does several circuits. This car had no power to the hevac display, no blower fans working even if i fed 12v to the circuit that lit the hevac & powered the cig lighter & radio. It would also keep the heated front screen on + other stuff that drained the battery.
    I got a second hand becm, swapped out the lower board with the original so the car kept its immo & ecu info. Fitted it & all was ok. Hevac worked ok including the fans & no battery drain. However this board was not fully populated with relays so some circuits did not work & failed fuses were reported. I went back to the original board & removed the relay & tested it. It worked ok, traced the circuit to a shorted diode
  4. #33
    khalcdi's Avatar
    Jun 2009
    hi;
    (F) RENAULT LAGUNA 2.2 DCI : engine stop at idle
    with CLIP only DTC is: DF072. Fuel pressure information. 5DEF
    ONLY CHANGE Fuel pressure solenoid.
  5. #34
    Dec 2010
    Peugeot 406 HDI. Sorted out our third one of these in the last 6 months with the same problem. Came in on the end of a rope (not so unusual for a Peugeot) It was a non starter as the sound deadening under the carpet was pi55ed wet through. Carpet was perfectly dry on all occasions. Stripped all the trim to gain access to the swimming pool and directly under the accelerator pedal there is a multi plug swimming with all the connections well and truly ~~~~ed. done away with the multi plug and now everything is working. Knock the plug out the floor so it drains away. dont know where the water is comming from, leave that for someone else to find.
  6. #35
    Ireland
    Skoda Octavia with engine managment light on for no reason. Check to see if the reverse lights are working and if not change relay for reverse lights. Problem solved and it was not the mass meter as diagnosed by stealer.
    Pager.
  7. #36
    Moderator
    krazylegz's Avatar
    Mar 2008
    Crowthorne / Sunny South Shields
    erratic idling on a nissan 2.2 dci, good changes it will be the suction control valve as this is a common fault on them apparently
    PS3= krazylegz120282
    please read the rules >>>>http://www.digital-kaos.co.uk/forums/f5/forum-rules-2/
    if you're new to forums and want to make your first post please read here>>>>http://www.digital-kaos.co.uk/forums...ul-tips-30279/
    if you like what people say please use the reputation or thanks button, dont just make a post to say thanks
  8. #37
    khalcdi's Avatar
    Jun 2009
    (F)
    GOLF5 TDI YEAR 2008 , whene i turn ignation ON the fan start to hight speed .
    you don't find any dtc in all ecu's
    after testing wires..... i find the probleme in pressostat sensor , i change it thats all.
  9. #38
    Liteace's Avatar
    Mar 2009
    On a rock
    Quote Originally Posted by Furax View Post
    you can use tcut but it takes a long time you are better off with genuine cutting compound like farcela G3. Also works on clock facias if you scratch it when removing.
    "Also works on clock facias if you scratch it when removing"
    Why O Why O Why would you want to remove clock facia ???
  10. #39
    Portugal
    Car: Skoda 2001/02
    Problem: electric steering works erraticly with steering wheel without pressure and light flicker
    Solution: Torque sensor breakdown (F)
    Regards all
  11. #40
    DK Veteran dik's Avatar
    Apr 2009
    In a mental institution
    Found on the web, might be of use
    CORSA ELECTRIC POWER STEERING
    There are some common faults with the Corsa Electric Power Steering
    that manifest themselves as one or both of these conditions
    1: The car pulls to one side or is easier turn in one direction when
    all else seems to be correct. E.g. Tyres equal, steering and
    suspension geometry good, brakes and wheel bearings good, driven on
    a straight and level road.
    2: When turning, the steering will randomly seem to jam or stick for
    an instant, and the steering wheel becomes suddenly heavy and then
    reverts to normal.
    Both of these can be rectified using a few commonly available tools
    and less than an hour's work. By many accounts the solution from your
    friendly Vauxhall Opel dealer is to replace the entire column.
    FAULT DESCRIPTION
    The most common problem by far with the Corsa EPS is caused by the
    torque sensing mechanical components wearing with age leading to an
    error with the torque sensor reading that gradually gets worse. The
    situation can be rectified by adjusting the position of the torque
    sensor to a new zero position.
    1: Steering pulls or has a preference for one direction
    Full details of this procedure are available with photographs
    elsewhere, but it is worthwhile mentioning now that you will need a
    good degree of dexterity and a few useful tools to achieve it. Tools:
    Medium sized Phillips screwdriver, T2.5 Torx bit, flexible driver,
    small 2BA or 1/4" ring spanner, 13mm ring spanner.
    Method:
    Turn the Steering wheel to expose the two pop-on screw covers on the
    retaining screws for the steering column switch covers, remove the
    covers and the two phillips screws underneath. Remove the three
    phillips screws underneath the lower steering column switch cover and
    remove the cover. Remove the fuse cover and take out the two screws
    beneath the fuse box to allow the lower section of the dash to be
    pulled away.
    On the lower right hand side of the steering column assembly just
    inside the dash, there are two torx screws holding the steel cover
    plate that protects the torque sensor. Remove both of these using the
    flexible driver and T2.5 torx bit. Remove the cover. Before
    proceeding, mark the position of sensor body relative to the steering
    column body.
    If you only need to reset the torque sensor position, you need only
    loosen the screws to allow adjustment. If you need to fix the
    sticking steering problem then the sensor must be removed. The torque
    sensor is retained with two more T2.5 torx screws. The lower
    retaining screw can be accessed fairly easily by pulling the lower
    right section of the dash away from the metal structure. The upper
    one is more difficult and may be slackened using the torx bit in a
    small ring spanner.
    Next, turn the steering column to gain access to the bolt that
    secures the lower steering column universal joint to the rack spigot
    that projects up through the floor. Remove the retaining bolt and
    swivel the joint away.
    If you have a short piece of plastic drain pipe or a cardboard tube,
    slide it over the universal joints so that the steering column is
    free to turn without jamming on anything (like your hands).
    BEFORE TURNING ON THE IGNITION, READ ALL OF THIS BIT!.
    When the ignition is turned on and the engine started, the EPS will
    drive the steering column depending on reading of the torque sensor.
    If you do this now, there is a chance that the wheel will be driven
    continously in one direction. The column has a position sensor at the
    top behind the steering wheel that will count 30 turns from end to
    end before it jams. Check this before proceeding. Then turn the wheel
    back to centre (15 turns from one extreme).
    Now be ready to turn off the ignition if the next step causes the
    wheel to spin rapidly. Turn on the ignition and start the engine. The
    steering may spin rapidly, Switch off if it does. Rotate the torque
    sensor fractionally and turn on the engine again. Repeat this process
    until the steering is still when the engine is running.
    Then, give the steering wheel a short tug in one direction and let it
    settle, then do the same in the other direction. The wheel may
    continue a little or might bounce back a little. If necessary adjust
    the torque sensor position until the behaviour is identical in both
    directions.
    Now switch off, and check the steering centre position by counting
    the turns, and reset it in the central position.
    Repeat the torque sensor setting procedure to ensure that the
    behaviour is identical in both directions. Adjust if necessary. When
    you are satisfied that the steering is balanced and neutral turn off
    the ignition, and tighten the sensor retaining screws.
    Refit the Sensor cover, re-assemble the lower universal joint, refit
    the covers and screws and test drive.
    2: Random Jamming or "notchy" steering.
    This fault is caused by the mechanical components that translate the
    steering column effort (Control Demand) into motion that is
    proportional to torque. Direction is inferred by the magnitude of the
    torque being positive or negative. This mechanical translation is
    managed using a slant-pivot coupling connecting the upper and lower
    parts of the steering column that operates a sliding collar normally
    held in a central position by springs. The motion of the slant-pivot
    coupling is limited, and at either extreme allows direct coupling
    between the upper and lower sections of the steering column. The
    torque sensor detects the position of the sliding collar and produces
    an electrical signal to represent the effort and direction of turning
    the steering wheel. The EPS system then activates the motor that
    drives the lower section of the steering column in the correct
    direction to reduce the sensor reading to zero. i.e. No more turning
    is demanded.
    The problem occurs when the slant-pivot coupling or the sliding
    collar bind or lock at some position in the travel. The components
    are lubricated when built, but the lubricant degrades over time and
    eventually hardens and dries where it is thinnest. When the steering
    is turned slowly or by a small amount the friction at some points is
    enough to make the coupling bind rather than slide, causing a zero
    torque reading that effectively removes all power assistance until
    the coupling moves. To the driver this seems like the steering just
    got very heavy or jammed for an instant.
    It is possible to reinvigorate the assembly using a mixture of
    ordinary gear oil and a molybdenum disulphide based additive such as
    molyslip or stop smoke.
    Method:
    Carry out the same procedure as case 1, then mark the correct
    position of the torque sensor and remove it.
    Inject no more than 15cc of the Oil & MoS2 lubricant mixture into the
    void around the sliding collar and replace the torque sensor
    carefully. It will be necessary to rotate the sensor until the sensor
    actuator engages with the sliding collar correctly. Until the sensor
    is correctly engaged it will fail to seat properly. Do not force it
    into place or use the screws to try and pull it into position. The
    sensor arm is biased to one end by a spring and it will have moved
    when the sensor was extracted. Offer it into place and feel for the
    situation where the sensor arm spring tension can be detected. When
    it is in the right position it will just go into place easily and
    then it can be rotated to the correct neutral position as previously
    marked.
    Before replacing everything else, start the engine and check that the
    steering behaves properly. If it turns in one direction switch off
    immediately and reset the torque sensor position by following the
    procedure for case 1.
    After lubricating the internal components, a few days may need to
    elapse before the lubricant penetrates all parts of the coupling.
    Over this time the steering will gradually become lighter and may
    start to favour one direction as the coupling finds a new equilibrium
    position. If this occurs it will be necessary to reset the torque
    sensor position again
    and a slightly easier option from one of the replies
    "You don't actually need to disengage the steering column. You can use a multi-meter or do what I did and jack the car up so front wheels of ground and adjust sensor and turn ign on and see if it trys turninig itself to left or right. If it stays straight then jobs done. (albeit not the most scientific way it is much less work and even with a few attempts still less works than disengaging the steering etc)."
    another happy customer
    Sent from my keyboard using fingers to type
  12. #41
    khalcdi's Avatar
    Jun 2009
    passat 2.0 TDI year 2009 , can't start the car , whene i turn ign ON i got nothing just klik klik klik klik.
    with VAS you can't diagnostic nothing only some calculator.
    after verefing i find the big relay in fuse box engine ( we have 2 relay one for air injection pump and the second for PRINCIPAL IGN CIRCUIT
    i change this one and car start again
  13. #42
    Feb 2012
    BMW 316
    Rear indicators faulty. Earth wire is too thin, remove and splice thicker earth wire (F)
  14. #43
    Mar 2012
    Default Saab 93 2.2 dti
    Some air mass and turbocharger pressure error codes, mil ligth one, poor performance, (only cars with electric egr) take plastic cover out of it clean everything and put some hight temperature grease. You get one new car, works on Opel and vauxhall too.
  15. #44
    DK Veteran tapiru's Avatar
    Tks guys some of those was wery useful and honest I applied and work
  16. #45
    ecutuners's Avatar
    Apr 2011
    United Kingdom
    Default vw 140 - 170 bhp
    Had a few of these come in not starting, dtc code for injection relay fault, the fault is a faulty piezo crystal injector, unplug each 1 and try to start, when you find the fauly one the car will run on 3 cyclinders
    Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
    ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
    EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
    DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
    Professional Engine Software Development
  17. The Following 2 Users Say Thank You to ecutuners For This Useful Post:
    PierreTheron (12th October, 2021), tepSIJA (26th May, 2020)
