hi,
what do I need to add to OM box to be able to pick up channels other than FTA channels?
please break it down for me like i'm a 5 year old as I have little technical knowledge
any help much appreciated!
hi,
Download this file...
RapidShare: Easy Filehosting
You will need to FTP to your box to be able to transfer files to it. For this you will need an FTP Program and a crossover ethernet cable. It's best if you can connect the box to your router as it's easier that way.
There's a guide here...
Dreambox Guides, Tutorials, Tips and Hints Blog Archive How to Connect your Dreambox to your PC
In the files that you downloaded, copy the contents of the keys folder to the /var/keys folder on your box. Copy the contents of the scce folder to the /var/scce folder on your box. Go to sky sports 1 and hold down the INFO button until the EMU manager comes up, press OK and it will restart the EMU. Wait and the channel should come on...that's it.![]()
Currys and Dixon won't have a crossover cable but you might have more luck at your loacal Maplins store.
It only takes a few seconds. If you've transferred the keys and scce files to the respective folders then you can also go to sky sports 1 then reboot the box using the shutdown menu, this will also restart the emu when it reboots.
Copy the files over, go to sky sports 1 and reboot the box from the shutdown menu (Menu > Shutdown > reboot now)
If I remember correctly you dont have cable and only the free sky channels.
if this is the case then you need to do a search on google for "cccam pay server"
if max is correct and you dont have cable but have a sky feed coming into the house, but you currently dont pay for skys services then you will have to do as max suggests.
we dont allow cardshare talk on here so you will have to google for more specific info, but basicly you pay a small amount to someone elses card with the keys being sent via the internet, your box needs to be connected to the net 24/7.
PS3= krazylegz120282
Last edited by qwertyballs; 25th August, 2008 at 12:05 PM. Reason: Automerged Doublepost
The keys in the cable sections won't work with sky.
Would have been good if you said you were working with sky from the start.
