Results 1 to 3 of 3
    Nov 2018
    Default Trying to renew 722.9 conductor plate with FVDI
    Ok I have an FVDI and it all seems to be communicating fine with the conductor plate on the bench, it connects and says software supported then trys to start the virginize process and fails really quick. After looking into it further it appears I don't have the .cff file needed for this plate. Does anyone know if its possible to use a different file? or maybe have the file I need? the 7G database I have is dated 1 10 2015, is there newer database? the file im needing is 0034460310.cff.est
    thank you or all the help in advance
    alex_r_2001's Avatar
    New Jersey ,, USA
    You need to download 7g database from abrites.. I had same problem all works fine now.
    Bllinda's Avatar
    Baltic
    you forgot to write ....
    car type:
    car model:
    or VIN:
    EHS HW number:
    SW flash version:
    SCN:
    Coding:
    today
    A topic that interests me
