Results 1 to 15 of 28
    diagtech2000's Avatar
    Jul 2013
    North of England
    Default yanhua 18-1 can filter
    can anybody please advise me on how to set these yanhua 18-1 can filters for different vehicles?
    i can see 4 possible bridge points in the corner of pcb
    s4
    w222
    w166
    bmw
    on the label on the bag it says for old style w166 short circuit to ground, i presume this means bridge 2 points?
    has anyone got any information on how to set these up for different vehicles?
    cheers
    Please hit thanks if this helped you!
    SEAT.'s Avatar
    CAPE TOWN
    On Merc make sure pin 1 just plug in select bridge ,Bmw u need to solder wires & select bridge
  3. The Following 2 Users Say Thank You to SEAT. For This Useful Post:
    rtbdiagnostic (13th December, 2018), VeryFastSnail (9th June, 2019)
    Nicolas9's Avatar
    Feb 2017
    Aruba
    In the right-bottom of the pcb you see the text W166. Bridge (connect) the 2 soldering points next to it.
    mahie's Avatar
    Nov 2015
    This filter function only with BMW/F -Model.
    NOT FUNCTION WITH MB,
    I have used more then 30 pcs.
    SEAT.'s Avatar
    CAPE TOWN
    I used it on my A45 W176 & its still on plan works perfect
  7. The Following 3 Users Say Thank You to SEAT. For This Useful Post:
    bersch8688 (12th January, 2019), claudio35 (4th January, 2019), rtbdiagnostic (4th January, 2019)
  8. #6
    brend's Avatar
    Oct 2015
    Same where
    MB W212 2014 FBS4 .......this filter not work .Tryed with 2 filter .
  9. #7
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by brend View Post
    did you try both bridge options? or which did you try?
  10. #8
    Jul 2013
    North of England
    yes i tried removing the w222 bridge and bridging the w166 point & it seems to be working ok
  11. The Following User Says Thank You to diagtech2000 For This Useful Post:
  12. #9
    brend's Avatar
    Oct 2015
    Same where
    Tryed everything .
    1.With all bridge sulution..........
    2.In ezs its just not work!
    3.And dash socket away work but after 2 days its dead (all light in dash up and nothing work )
    One job done twise!Totaly rise time!
    So.......this filter its just totally st!!!
    Quote Originally Posted by Nicolas9 View Post
  13. #10
    davecooper47's Avatar
    Dec 2010
    Tryed everything .
    These filters are not meant to go in EZS.
  14. #11
    SEAT.'s Avatar
    CAPE TOWN
    I used it on a W205 2014 a few days ago,still good ,plugged it in behind cluster 5min job
  15. The Following 2 Users Say Thank You to SEAT. For This Useful Post:
    rtbdiagnostic (8th July, 2019), SKYTON (10th April, 2019)
  16. #12
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by davecooper47 View Post
    What ever !!!!
    Dash socket away not long worked! 2 days and dead!!
    Quote Originally Posted by SEAT. View Post
    Probably for w205 its good.
    But for w212,w204 facelift its not work.
  17. #13
    SEAT.'s Avatar
    CAPE TOWN
    I know they selling blue & green boards im using green as they more expensive.
  18. #14
    bursuc's Avatar
    Oct 2011
    inside MCU
    What ever !!!!
    How to bridge for vito w447 ? or what other solution?
    BR
    Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
  19. #15
    w447 tried and not work........w176 two cars till now and all perfect.....green pcb
  20. The Following User Says Thank You to d.zio For This Useful Post:
