Results 1 to 13 of 13
Hybrid View
    Oct 2015
    Default Audi Dash RB8 not work
    Hi, I have exactly the same problem like in this thread:
    https://www.digital-kaos.co.uk/forum...light=audi+rb8
    How can I solve the problem? Read 24C08 and post here??
    Oct 2015
    LV
    Yes, post your dump
    Oct 2015
    This is eeprom, please I need solution for this dash.
    8E0 920 930 R
    brend's Avatar
    Oct 2015
    Same where
    If put test dash vcds away ,needles work?
    Oct 2015
    Needles not work in car, in bench yes. Illumination not work in car.
    Error 00576 KL15.
    Green connecor ok, possitive and gnd.
    dominik.m's Avatar
    Jun 2009
    POLAND
    Your dump is corrupt. Try this file.
  7. The Following User Says Thank You to dominik.m For This Useful Post:
    Perryking (17th January, 2019)
    Oct 2015
    With your dump dash not power up and car doesnŽt start.
    Please any other solution?
    Oct 2015
    Thanks IŽll try and report here.
  10. #9
    marina_rv's Avatar
    Ukraine
    dominik.m - please help my.
    DEF problem
    Thx.
    please press the little THANKS
  11. #10
    dominik.m's Avatar
    Jun 2009
    POLAND
    Quote Originally Posted by marina_rv View Post
    DEF problem
    Thx.
    Have you tried to change the value? Is the cause different?
  12. #11
    dominik.m's Avatar
    Jun 2009
    POLAND
    I do not want to believe, but ok.
    Another solution is this.
    Read the coding with VCDS and save.
    From your ori file you have to read the immo data and save. Carprog, for example with OBD.
    Then write another checked file from the dash with the same HW.
    Next . Write ori immo data and ori coding.
  13. #12
    Oct 2015
    IŽll check eeprom tomorrow, maybe bad solder.
  14. #13
    Oct 2015
    I manage to power up the dash but still same problem, oil pressure and no needles and illumination. Problem is in flash, but I dont have the tool for repair this dash.
