    Aug 2014
    Exclamation Problems reading 0F82B MC68HC05E6
    Hi i tried to read MC68HC05E6 Mask 0F82B from mercedes ESL lock with Xprog,Orange,Carprog... no luck.
    I still have to try UPA if i find the software cd..
    I also tried connecting like this picture with quartz and resistors... nothing
    So am i missing something here ?¿?
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    the wiring diagram have fault...
    O5 read this mcu sure like charm...check again wiring in O5, need lift first pin i think...
    many thanks to friend kevfield
  3. The Following 2 Users Say Thank You to daxxer For This Useful Post:
    droidwayne65 (23rd January, 2019), monstermurga (23rd January, 2019)
    droidwayne65's Avatar
    Aug 2015
    North America
    Quote Originally Posted by daxxer View Post
    Yup. before I discovered AK500 would do it easily, this thread had the right advice.
    https://www.digital-kaos.co.uk/forum...-will-not-read!
    <---- Coin of the Realm.
  5. The Following User Says Thank You to droidwayne65 For This Useful Post:
  6. #4
    Aug 2013
    Macedonia
    i use this connections to read that mcu
    work with upa 100% tested on mb keys bike immo box ...
    inside is pdf with connections and txt manual how to adjust upa to read in circuit
  7. The Following 6 Users Say Thank You to nenadgorgi For This Useful Post:
    BUSCADOS (30th April, 2020), monstermurga (23rd January, 2019), pollito128 (17th January, 2020), solukey (16th July, 2019), Stevens Ferreira (30th June, 2022), zyjekrc51 (8th January, 2020)
  8. #5
    Aug 2014
    Thanks could finally read it with orange desoldered from board to orange adaptor.
    Im not familiar with this chip but got eeprom 1KB and ROM 6KB file. Do they look OK files for Mercedes ESL ?? I attach files
  9. #6
    BUSCADOS's Avatar
    Rosario
    Hola, gracias. a mi me funciono perfecto para leer y grabar con vvdiprog. Gracias nuevamente
