if all injectors are plug open, the fault p1641 disappears
HELP == thanks + reputation
A topic that interests me
Immo is ok
Ecu --- bsi --- ok
upload printscr from PP2000 bsi and ecu
Hi first check injector wiring between ECU and injectors ,second option replace ECU
Hi mates,
I have the same situation with one 2.0 hdi SID801A. Did you manage to fix it?
thanks a lot
I had it two times... Both times was mehanical problem, broken valves inside engine and timing belt sliped...
alclot (5th September, 2019)
