Results 1 to 15 of 15
Hybrid View
    Apr 2013
    Default AC Delco e87 bricked Opel Meriva B 1.7 cdti Astra J
    So I had this spare ECU and decided to do some testing..
    I read already that I should have original Kess or IO terminal to clone these ECUs but gave it a try with Kess (clone) and managed to read it (2MB), it took around 1h.. So I grabbed another ECU with the same HW number and tried to write this backup.. it took only 2 minutes and ended up with errors..
    of course ECU doesnt boot up anymore, no communication Any way to bring it back to live? or spare parts only?
    Meat-Head's Avatar
    I got couple the same, as it's dead, nothing to loose, see if you can find boot pin info for it
    Dec 2009
    You need to read password first to have access via boot mode. OBD read with Kess is partial thats why you cannot clone.
    You can try SPS programming with MDI. Maybe it can recover it
    Apr 2013
    Quote Originally Posted by exe123 View Post
    Ok, all clear now - a bit too late
    So the reason behind my spare ECU is bricked now is wrong (partial) flash (different version) loaded to ECU that was made for different car..
    I'm wondering - maybe it's the right time to get I/O terminal with Delco plugin?
    Meat-Head's Avatar
    You got link to I/o terminal information?
    Apr 2013
    What do you mean?
    Dec 2009
    Apr 2013
    yes, i have seen that, so it looks like it does the job and its possible to clone this ECU with proper plugin..
    Another question related to this ECU - has anyone ever tried to remove pcb from the cover?
    I managed to open it but then I got stuck and seems to be very well glued, pcb doesnt move at all.. any ideas?
    The problem with it is faulty control circuit for glow plug - trying to get access to control section but need to remove whole pcb first..
    Mar 2010
    Portugal
    Quote Originally Posted by gomegarules View Post
    Did you managed to open ecu totally.
    I've same problem here with the number 2 glow plug with weak current.
    Dec 2009
    Seems to be easier to do it by OBD. Get pincode and learn with opcom or gds
  11. #11
    Aug 2018
    East Pole
    Hello, they have a good silicone to hold the pcb on case, the plugs are inserted by pressure into the pcb holes. Verry hard to get it outside the case. Ioterminal does reprogram this, bit since it cannot be recognized the right addresses in the flash, it cannot be possible to recover it. Never try to reflash them if you don't have the propper tools. I have made my mistakes too. Better sps or opel tools to get carpass, reset and reprogram. Much easy and safe, too.
  12. #12
    Jan 2010
    Quote Originally Posted by volorucinski View Post
    You right about the proper tools volorucinski looks like i bricked this ecu also. I've read this ecu by clone Kess, it took about 20min. Maps looks ok, nothing is missing, but when I wrote file back I got error on 98%, recovery mode also didnt help. Car is not starting now, I've still communication with ecu, KESS do ID no problem, I can read it again no problem, tried ori KESS to write ori file back also and no joy (full process going with no errors), SPS programming doesn't have updates for this ecu. Only fault in ecu is P0601 - INTERNAL CU MEMORY CHECKSUM ERROR.
    Is there any way to get this ecu working? I attached ori file and also reading after when car is not starting
  13. #13
    Bllinda's Avatar
    May 2010
    Baltic
    Prit/scryn global.tis/ecu.data uploaded here.
    This is the current topic for me in 2022.10.
    508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
    today
    Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
    A topic that interests me
  14. #14
    Jan 2010
    Quote Originally Posted by Bllinda View Post
    What you mean Bllinda?
  15. #15
    Bllinda's Avatar
    May 2010
    Baltic
    Look here ....
    today
  16. The Following 2 Users Say Thank You to Bllinda For This Useful Post:
    asto (21st June, 2020), baronrojo (19th March, 2023)
