Results 1 to 9 of 9
    Default Peugeot 307 valeo BSI 9650217980 Fault
    i Have a peugeot 307 sw 2003 1.4hdi whit Valeo J03 BSI 9650217980,
    the problem is i dont have the 12v on rear electric windows switch so they dont work as i could check on the electric diagram the 12v cames direct from the BSI pin but it does not have it, does any off you guys have this problem befor ?
    Jan 2016
    Common problem with peugeot BSI... Open it and check from that pin on what IC or relay it goes inside BSI and replace it.
    Hi , I don’t have the electric scheme from this BSI and my Sedre is not working
    Can some one help me out whit the electric scheme from this BSI?
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Post vin number.
    Bllinda's Avatar
    Baltic
    Post
    I think it's easy to reinstall ....
    Quote Originally Posted by MI16rs View Post
    today
    A topic that interests me
  7. The Following User Says Thank You to Bllinda For This Useful Post:
    rafal (20th June, 2019)
    Default 307
    Hi its VF33E8HZB82882423
    Quote Originally Posted by PSAcars View Post
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. This is all I can get from peugeot, hope it helps.😁
  10. The Following User Says Thank You to PSAcars For This Useful Post:
    MI16rs (28th June, 2019)
  11. #9
