Common problem with peugeot BSI... Open it and check from that pin on what IC or relay it goes inside BSI and replace it.
Regards
i Have a peugeot 307 sw 2003 1.4hdi whit Valeo J03 BSI 9650217980,
the problem is i dont have the 12v on rear electric windows switch so they dont work as i could check on the electric diagram the 12v cames direct from the BSI pin but it does not have it, does any off you guys have this problem befor ?
Regards
Hi , I don’t have the electric scheme from this BSI and my Sedre is not working
Can some one help me out whit the electric scheme from this BSI?
Hello to all. Post vin number.
IF I HELPED YOU PRESS THE " T " BUTTON
This is the current topic for me in 2022.10.
508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
today Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
A topic that interests me
rafal (20th June, 2019)
Hello to all. This is all I can get from peugeot, hope it helps.😁
MI16rs (28th June, 2019)
