    Nov 2011
    Default Subaru login code
    Hello.
    I don’t know if this helps, but I have a Subaru Liberty / Legacy and I may have found the location of the login pin code.
    Inside the BCM there is a A01A ic which is a Rohm 24A01A.
    At address $06-07 and repeated at $26-27 is a hex value. In this case 25CE. Convert to DEC and you get 9678 which is the same a the Security ID tag accidentally left with the keys from factory.....
  2. The Following 4 Users Say Thank You to madman47 For This Useful Post:
    EFI Guru (12th March, 2025), lupu_sandu (13th January, 2025), SAMDoctor (24th March, 2021), scotlock (21st August, 2019)
  3. #2
    Jun 2019
    Good find! I have checked an eeprom that was uploaded here that position 0x06-07 and positions 0x26-27 also match On another eeprom, 24c02 from Impreza positions 0x06-07 and positions 0x36-37 match. Can upload files here if you want to have a look at them.
    Still have to check these are the right pincode to code keys
    Nov 2011
    I can now confirm this is correct. It was tested today.
  5. The Following 3 Users Say Thank You to madman47 For This Useful Post:
    EGA3 (8th September, 2021), harrison (24th January, 2020), PierreTheron (30th June, 2022)
  6. #4
    Feb 2025
    Digging this up from the past, I've got a couple of BIUs I'm trying to work out how the security ID is stored.
    This first one is from a 2014 SJ Forester, I have the ID 33469, but can't see how it is stored:
    The second more important one is the BIU from a 2010 SH Forester, which I don't have the ID for and need to code the keys. I tried converting a bunch of the hex values to decimal, but none were correct in SSM3
    Bllinda's Avatar
    Baltic
    .... damp? And from where?
    today
    A topic that interests me
  8. #6
    Feb 2025
    Quote Originally Posted by Bllinda View Post
    I'm not sure what you mean, i never said anything about damp?
    All I'm trying to do is work out how the security ID is stored in those two BIU eeproms I've posted the dumps from above
