Results 1 to 11 of 11
    Sep 2008
    Default FAILURE OF TRANSFER OF KEYS AND ROMS
    HI THERE I AM TRYING TO GET PREMIUM CHANNELS AND WHEN I DROP AND DRAG FILES THE MESSAGE IS TRANSFER FAILED
    PLEASE ADVISE
    DK Veteran portbhoy's Avatar
    Sep 2008
    You got to browse to the files right click and transfer
    Sep 2008
    THE FILES ARE STILL NOT TRANSFERING
    ANY ADVICE
    Jul 2008
    what are you using to transfer - flash fxp?
    Sep 2008
    YES I AM USING FLASH
    Sep 2008
    Do you definately have a connection? Only reason I can think of that the files wont transfer.
    Moderator
    krazylegz's Avatar
    Mar 2008
    Crowthorne / Sunny South Shields
    double check you have a connection as stated by portbhoy and try to restart box, if still no good you might need to reflash
    and turn off caps lock, looks like your shouting m8
    PS3= krazylegz120282
    Sep 2008
    cheers i shall try that later
    <--davidward999 added 179 Minutes and 5 Seconds later...-->
    hi there sorry just wonted to get further information for later.
    how do you mean if i am connected. i shall try and explain as simple as poss,please bear with us as i am a little green at this. The dreambox files come up and the pc establishes a connection. i then drag and drop or transfer as instructed and then a number of messages in green appear and finally a message in red says transfer failed.
    any further info please
    Last edited by gingerninja; 16th September, 2008 at 12:16 PM. Reason: Automerged Doublepost
    Jun 2008
    get internet-soft's ftp commander and try again. add a server (your box using root and dreambox as username and password)
    If you can't copy files on try copying some off and see what happens.
    You might have no space left or a locked image and have thus to reflash as said above.
    V.I.P. Member Donnie Darko's Avatar
    May 2008
    As said further up,can you actually connect to the box?once connected you should see in the righthand window the entire file content of the db.If not you aint connected.
  11. #11
    Sep 2008
    hi yes all the files come up from dream box and have downloaded new flash. still file is not transfer. i am trying fxp
    <--davidward999 added 13 Minutes and 39 Seconds later...-->
    hi there just tried ftp and message is saying host not found (winsock error #11001
    please advise
    Last edited by gingerninja; 16th September, 2008 at 06:29 PM. Reason: Automerged Doublepost
