Results 1 to 9 of 9
    May 2018
    Serbia
    Default saab 9.3,2.0t,trionic t8 immo off
    Need immo off saab 2.0t,2004,trionic t8,ecu nr 55353231,flash AM29BL802CB.
    brend's Avatar
    Oct 2015
    Same where
    Just copy/paste from ori to donor?
    May 2018
    Serbia
    Quote Originally Posted by brend View Post
    I cant because ori flash is destroyed.
    Bllinda's Avatar
    Baltic
    It's not that easy to do ....
    today
    A topic that interests me
    May 2018
    Serbia
    Quote Originally Posted by Bllinda View Post
    I removed flash from donor ecu and read it with tl866 programmer,but flash from ori ecu is damadged,and i cant read it,that is the problem
    May 2020
    hey, did you solve this problem?
    Jul 2023
    Hi Guys ,
    i have just down loaded the zip file , i have a problem with a saab T8 the original ecu is destroyed and i have purchased a replacement 2nd hand one. i was going to remove the EEprom but i cant identify it. so i am hoping that this down load will remove the immobiliser. i am no expert with saab so if you have any more information i would be very grateful on the programming procedure, or if you think swapping the eeproms over i am desperate with this so any info please
    Feb 2022
    i have the same problem, anyone solved this?
    May 2024
    Same issue aswell stuck wgat to do ??
