Page 1 of 23 12345611 ... LastLast
Results 1 to 15 of 355
Hybrid View
    DK Veteran manocao's Avatar
    Default Automotive Software Collection by manocao
    note: some people report that some interfaces do not connect because of firewall, so disable it when using diagnostics software. it is also recommended to disable internet connection and antivirus. in windows vista is also necessary to have administrator rights and to disable uac.
    AS I DONT WANT TO TAKE THE RISK OF LEGAL ACTIONS, ONLY FREE OR NON-MODIFIED SOFTWARE AND PREVIOUSLY EXISTING LINKS IN THIS FORUM OR FOUND IN INTERNET BY GOOGLING, WILL BE RELEASED HERE
    ASK OTHER MEMBERS OF FORUM FOR THE SOFTWARE YOU NEED OR GOOGLE IT OR TRY THESE OTHER AUTOMOTIVE SOFTWARE COLLECTIONS:
    http://www.vo2ov.com/Automotive-Soft...g-_683886.html
    Automotive Software Collection - Katz Forums
    Automotive Software Collection - Rapid.org
    Automotive Software Collection - gigle.ws
    http://eng2all.com/vb/t25247.html
    http://dkgaragesoftware.blogspot.com
    VAG-COM 409.1 KKL INTERFACE ----------------------------------------------------------------------------------------
    vag-com 311.2-n with keygen
    http://www.digital-kaos.co.uk/forums...16/#post302184
    http://www.digital-kaos.co.uk/forums...tml#post284272
    DISCONNECT INTERNET BEFORE INSTALLING AND RUNNING SOFTWARE
    IN VISTA, DISABLE UAC (GOOGLE IT TO KNOW HOW)
    vag-com 409.1-s final, i found it on internet by googling
    MEGAUPLOAD - The leading online storage and file delivery service
    vcds lite 1.0 (new vag-com 409.1)
    http://www.digital-kaos.co.uk/forums...racked-113698/
    great free alternatives to vag-com 409.1:
    monoscan 2.12 supporting kw1281 and kw2000 protocols
    requires free registration (for unregistered control units, the connection duration is limited to 60 seconds)
    Home (MonoScan)
    wbh-diag 0.89 supporting kw1281 protocol
    WBH-Diag 0.88 freeware for KW1281 protocol based Non-CAN VAG cars and 409.1 interface
    audi-vwtool 2.0.9 supporting kw1281 protocol
    http://shotta.big4.pl/photo/KJS%2020...owe/vds209.exe
    unidiag 0.4.0.3 for alfa-fiat-opel packed by manocao with 38 def files and 9 dtc files
    with corrected Test_BoschABS57ASRTC.def
    Digital Kaos
    fiat ecu scan for kkl vag-com 409.1 interface
    http://www.digital-kaos.co.uk/forums...stered-110099/
    http://www.fiatecuscan.net
    scantech OBDII 1.35 (iso9141 and kw2000 protocols, non can-bus) for KKL interfaces (vag-com 409.1 blue cable)
    http://www.digital-kaos.co.uk/forums/attachments/f104/9888d1264093897-automotive-software-collection-manocao-fullscantechobdii.zip
    OBDTool 1.2.60 (iso9141 protocol, non can-bus) for KKL interfaces (vag-com 409.1 blue cable)
    http://www.minskaner.narod.ru/obd1260.zip
    Collection of D.I.Y. serial OBD2 ALDL dumb interfaces for VAG-COM 409.1 and KKL soft
    TECH-2 MULTIPLEXER INTERFACE (OR VAG-COM 409.1 KKL INTERFACE BUT ONLY ENGINE ECU PIN7) -----------------------
    mocpo (opcom demo with all measuring blocks)
    Mocpo - Download
    index_demo
    http://www.vezerdiagnosztika.hu/AB-COM/1.zip
    http://www.vezerdiagnosztika.hu/AB-COM/2.zip
    http://www.vezerdiagnosztika.hu/AB-COM/3.zip
    http://www.vezerdiagnosztika.hu/AB-COM/4.zip
    http://www.vezerdiagnosztika.hu/TECH...20for%20KL.rar
    http://www.millisi.net/download/VAG/TECH2.rar
    OP-COM V2 INTERFACE ------------------------------------------------------------------------------------------------
    http://opcomforum.yolasite.com
    http://www.digital-kaos.co.uk/forums...tml#post364253
    last drivers 2.06.00 http://www.digital-kaos.co.uk/forums...tml#post386958
    ALL YOU NEED TO REPAIR OPCOM INTERFACE
    OPCOMFUT 2.9
    v2.9
    - No Aktivation in OP-COM Fut needed anymore!
    - Creation O***MRD.DLL in Version 1.1.0.0 or 1.0.2.0
    http://www.digital-kaos.co.uk/forums...pcomfut29b.rar
    source:
    OPCOM again.... what so it mean?
    file seems to be corrupted but it is not:
    rename file to .rar
    unrar
    rename extracted file to .zip
    then unzip and youll find it
    ELM327 INTERFACE ----------------------------------------------------------------------------------------------------
    scantool.net 1.13
    ScanTool.net: OBD-II Software Front End | Get ScanTool.net: OBD-II Software Front End at SourceForge.net
    scanmaster elm 1.9 full for elm327 (bugs free)
    search on automotive software collections above on top
    vauxcheck 1.21 full for elm327
    opel cars supported Gendan VauxCheck :: Coverage
    Upgrade your ELM327 v1.2a from 9600bps to 34800bps
    http://www.digital-kaos.co.uk/forums/f104/elm-interface-buy-94874/#post462810
    FTDI DRIVERS AND UTILITIES ------------------------------------------------------------------------------------------
    elm327 v1.2a, tech2 and vag-com 409.1 clones drivers
    Windows 2000, XP, Server 2003, Vista, Server 2008, Windows 7 and Server 2008 R2 (x86 and x64)
    2.06.00 http://www.ftdichip.com/Drivers/CDM/CDM%202.06.00%20WHQL%20Certified.zip
    2.06.02 http://www.ftdichip.com/Drivers/CDM/CDM20602.zip
    Windows 98 and Millenium
    1.09.06 http://www.ftdichip.com/Drivers/VCP/Win98/R10906.zip
    Digital Kaos
    ftdi drivers uninstaller ftclean
    http://www.ftdichip.com/Resources/Utilities/FTClean.zip
    mprog3.5 ftdi eeprom programmer
    http://www.ftdichip.com/Resources/Utilities/MProg3.5.zip
    ft_prog 1.3.1 ftdi eeprom programmer and VNC1L firmware programmer
    http://www.ftdichip.com/Resources/Utilities/FT_PROG%20v1.3.1.zip
    requires the Microsoft .NET Framework 2.0 installed on your system to run the application
    http://www.microsoft.com/downloads/details.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5&displaylang=en
    OTHER INTERFACES ---------------------------------------------------------------------------------------------------
    Uniscan or Euroscan's VISA 1.83 by manocao for u all
    RENAULT XR25PC for old cars (fenix, renix...)
    http://www.digital-kaos.co.uk/forums...e-and-software
    VISA 1.83 MultiBootCD and MultiBootUSB by manocao
    http://www.digital-kaos.co.uk/forums...SB-by-manocao/
    build your own ALDL interface: schematics and software
    GM 8192/160 Baud ALDL Interface
    Digital Kaos
    ALDL OBD1 OBD cable OBDI OBD2 engine codes
    10 pin to 16 pin op-com adapter pinout and following posts on same page
    http://img251.imageshack.us/img251/1...colspinout.jpg
    Digital Kaos
    Digital Kaos
    Digital Kaos
    Digital Kaos
    Andrew's GM ALDL Stuff...
    http://download.efilive.com/Software...5_305_Eval.exe
    EFILive V4 Eval License - Valid Thru Dec 2010 - EFILive Forum
    EFILive Collate - EFILive Forum
    Index of /downloads/tuning-bins/EFILIVE
    www.oldholdens.com - /temp/carstuff/VN-VP-VR/aldl/
    www.oldholdens.com - /temp/carstuff/aldl/
    http://www.ttspowersystems.com/softw...TEST-Setup.zip
    SUPERLINKS -----------------------------------------------------------------------------------------------------------
    Elm Electronics Help - OBD Links
    Check Engine Light OBD2 OBDII scan tool OBD
    https://www.scantool.net/support/index.php?_m=knowledgebase&_a=view
    DTCSearch.com - Search Engine for OBD-II Diagnostic Trouble Codes (DTCs)
    Index of /Scion_Docs
    Index of /images/04_xB_Repair_Manual
    Index of /dersler/muh100/2007-2008/Cesitli/Deutz Engine
    RENAULT DOCUMENTATION | Renault Moteur / Engine
    Measurecalc - Conversi?n de Potencia
    http://bevo.mercedes-benz.com/bevolistenmain.php
    ren
    Index of /carmechanic.co
    16 pin J1962 OBD-2 car special connector diagram and applications @ pinouts.ru
    BUS INIT: ...ERROR - Powered By Kayako eSupport
    Category:Fault Codes - Ross-Tech Wiki
    ChipTunaWarehouse
    OBD2 Interface for diagnostic over OBD
    DTC Table
    Elm Electronics Products - OBD ICs
    Elm Electronics Products - Data Sheets
    Google Traducir
    How do I know whether my car is OBD-II compliant? - Powered By Kayako eSupport
    How to clear or reset the Check Engine Service or Service Engine Soon Light
    GM General Motors OBD Trouble Codes
    OBD-II Check Engine Light Trouble Codes
    BAT Auto Technical-Professional mechanics giving advice-An Educational Site w/ OBD2 Trouble Codes and Technical info & Tool Store.
    SRS Module Repair - SRS Airbag Light Reset - Reset Airbag Computers - Manually Reset Airbag - Air Bag Module Repair Service - Airbag SRS Systems - Remove Auto Crash Data
    http://youyoukiller.free.fr/ecu/
    http://autoecutools.com/download/
    http://www.motordiag.cz/download/
    http://www.vchecker.com/down/
    http://myrezo.free.fr/
    http://download.autosvs.com/software/
    index_en
    Lexus LS400: How to Turn-Off the Air Bag Light / Clearing Diagnostic Code 41
    http://www.millisi.net/software-download.htm
    http://shotta.big4.pl/photo/KJS%202006/Programy%20do%20interfejs%f3w/OBD%20car/
    OBD2 Standards/Terms - obd2crazy.com Tech Info for OBD2 OBDII
    OBD-2 ISO 9141-2 (14230-4, KWP2000) simple RS-232 Connector Pinout - AllPinouts
    OBDII Diagnostic ScanTools and code-readers
    OBD-II Hardware
    OBD-II OBD-1 Infos
    OBD Productinfo OpelScanner
    OBD-II ScanMaster-ELM
    OBD-II Productinfo ELM327
    OBD-2 Kompatibilit?t
    OBD-II Compatibility
    OBD-II Abbreviations
    OBD-2 Techn. Infos
    OBDPros
    PCM Fault Codes
    PIC18F2580
    http://rapid.org/board/showthread.php?t=198809
    Reset Air Bag Light
    http://www.minsk555.narod.ru/software.htm
    http://www.minsk555.narod.ru/index.htm
    http://www.minsk555.narod.ru/suppobd.htm
    SK Pang Electronics - RS232 Data
    AKM Electronics: Technical Information
    AKM Electronics - Diagnostic Scanning Software
    Which OBD-II protocol is supported by my vehicle? - Powered By Kayako eSupport
    http://www.sinodownloads.com/down/download/ecutool/
    http://www.berton.es/recursos/indices/INDICE%20VEHICULOS%20OPEL%20V%206-9%20.pdf
    http://www.op-com.hu/Downloads_EN.aspx
    http://www.remixbg.com/Documentation/BRC/Other/VARIAT_SCELTA_TA010986_1_ML.PDF
    http://www.rapidshare1.com/ddl6/opel%20tis/
    Motor CORSA X12XE
    http://op-com.wikidot.com/en:start
    Yahoo! Groups
    The Alfa Romeo 145 & 146 Technical Resource Centre - OBD KWP2000 Diagnostics Information
    Volo Performance - Chip Tuning Made Easy
    Hoofdpagina EN - op-com
    http://www.hex.co.za/vaginfo/index.html
    http://www.digital-kaos.co.uk/forums/f104/vag-com-409-software-crack-25528/index9.html#post421058
    http://www.er-forum.de/obd-diag-dl/
    http://www.obd-shop.com/danila/index.php?cid=26&id=27&lang=de
    http://sites.google.com/site/outilsobdfacile/telechargement
    http://www.forum-auto.com/pole-technique/section12/sujet118225.htm
    Freediag - Vehicle Diagnostic Suite
    opendiag: By Thread
    UniDiag : UniDiag
    http://home.wanadoo.nl/sanderqv/diag/
    GNC > GNCUSERS • Ver Topic - Scanner OBD2
    http://hem.passagen.se/tomasf/obd2/
    Software for the vehicle diagnosis
    http://philippe.boursin.perso.sfr.fr/pdginj.htm
    http://philippe.boursin.perso.sfr.fr....htm#technique
    http://opcomforum.yolasite.com/
    http://peb.pl/literatura-programy/82...yka-tylko.html
    http://forum.vectraklub.pl/index.php...st__p__1358135
    INFO ------------------------------------------------------------------------------------------------------------------
    info about elm327, tech2, op-com amd vag-com interfaces
    diagnostics hardware
    installing drivers of an interface
    best cheapest ebay searches
    item, Libros, Revistas y Comics y Juguetes en eBay.es
    (whole world, buy it now, lowest price+posting)
    keywords: vag kkl, sb kkl, vag can, k+can, tech2, obd2, op-com, elm327, can obd2, obd2 v1.2a, obd2 v1.3, obd2 v1.5a...
    manual multiplexer (also for fiat ecuscan, get a longer switch for more pin connections, more info Fiat ECU Scanner - Fiat/Alfa/Lancia ECU Reader and here working vag-com 409.1)
    see my build here working vag-com 409.1 and here working vag-com 409.1 other here Modifications and multiplexers for the vehicle diagnosis
    Last edited by manocao; 1st April, 2015 at 12:02 PM. Reason: Removed contentious link .....
  2. The Following 13 Users Say Thank You to manocao For This Useful Post:
    asiprens64 (20th December, 2013), bob carr (7th September, 2013), DANILLO (7th May, 2019), gogoli (20th April, 2015), ilhafi (15th February, 2016), jlandim (6th November, 2023), jousam15 (6th January, 2015), mis (20th August, 2013), nikeady (22nd December, 2016), pityu21 (30th March, 2013), sebastian (4th April, 2013), thangtn (12th February, 2014), zogic (27th June, 2019)
  3. #2
    added more software for tech2, opcom and elm327
    added more info
    carsoft Mercedes Benz interface
    Work that with all Carsoft Version?
    Quote Originally Posted by Astraracer View Post
    it works with no can cars up to 2004
    i think it works with carsoft 7.4 u can download here http://www.digital-kaos.co.uk/forums...lection-65195/
  6. The Following User Says Thank You to manocao For This Useful Post:
    poul77 (18th September, 2014)
    Nov 2010
    Where i download schematic interface for carsoft MB?
  8. #6
    Ecuador
    Smile
    Quote Originally Posted by manocao View Post
    added more info
    Gracias estoy probando el software, tal vez tienes Isuzu for tech2, si lo tienes lo podrias subir y gracias por tu trabajo
  9. #7
  10. #8
    download.qclt.com - /
    Benz DAS 2012, BMW TIS,MB Training, Honda HDS, Lexia, Proxia3, VAS_PC and more direct download ISO links.
    Share for all
    B.R.
  11. #9
  12. #10
    Junior Member oscarescodo's Avatar
    Sep 2010
    Default THANKS
    [ThaNKS MANOCAO VERY USEFUL FOR ME ALL THIS INFORMATION.
  13. #11
    added scanmaster freeware 0.4.0.0 for elm327
  14. #12
    added converting cheap vag-com 409.1 blue cable into opel tech2 manual multiplexer
  15. #13
    Oct 2008
    On Earth
    I tried your solusion yan year ago on an friend Opel Astra 2000.
    The interface was VagCom 409 ( I did thats kind multiplexer for my Alfa - I did it to connect to pins 1,3,7,8,9 and 12)
    How I said I tried and it conected just on ECU on 7.
    AirBAg, ABS dosen't.
    If some one tried and it works, let us know, maybe I did a mistake.
  16. #14
    Quote Originally Posted by mattydr67 View Post
    remember what software you used? it should be tech2, abcom or opcom demo
    i would select pin in switch before ignition on and starting program
    i didnt built the interface yet but want to, lets see if i find the switch and try on opel car
  17. #15
    Oct 2008
    On Earth
    I used tech 2 and abcom its pretty same thing.
    Yes first time I selected the pin after start the engine.
    Someone said that it didn't worked because it is a USB interface and he said that is a serial one it will work. But I didn't tried on a serial one just on usb.
    Pins for tech 2 are 3, 7, 8 and 12
    How I said I did it for my Alfa Romeo to use it with UNIDIAG and ALFADIAG and then I tried on an Opel Astra 1.7 from 2000 engine Y17DT
