I can make change different cam, i make few Vivaro, Trafic with engines from Laguna...
Possibly a long shot but a friend of mine has just put a 2.0m9r engine from a 2010 Laguna 3 into a 2008 Vivaro to replace a very dead M9r (snapped chain 4 snapped injectors)
Although it will start and run albeit with a rough idle. It has a cam position fault caused by the pickups for the cam sensor being different. Vivaro has a single lobe on the cam for the cam sensor and the Laguna sourced engine has multiple lobes.
Obviously the cam can be changed but would like to avoid pulling the injectors on this engine if possible.
If possible and if anyone knows how the ideal would be to modify the ecu to recognise the reading from the cam sensor.
Cromwe11 (23rd October, 2019)
Can you do one for me ?
Was 780-6 2.0 84. And what kind of engine did you park ? What kind of ecu she controls
This is the current topic for me in 2022.10.
508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
today Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
A topic that interests me
Replacement engine is 744 from Laguna 3 ecu is EDC16 (Haven’t got the Laguna ecu but can get hold of it)
check and give answer
Cromwe11 (5th January, 2020)
Sorry for the delay, had no luck with Taraba23's files. I just changed the cam in the end and all good.
Bllinda (16th January, 2020)
