Results 1 to 15 of 15
    Aug 2010
    Cool Renault Kangoo UCH N2-x76 clone
    I read herre that posible only change the EEPROM 93C66 to start the Car. But ...
    i have the damage ECU ( only Turn light are always blinks) and secocond scrapt ECU N2x76 but Hardware H V5 are little bit other. Second Hand is HV4.7
    if i copy the eeprom Car wound Start and After i read the eeprom Alain it shows other dump i have prog and Check.
    how is ist posible to clone this UCH. MUST I CHANGE THE MCU?
    thnx for help
    and all members here stay healthy
    Romania
    Swap eeprom,it should work
    Aug 2010
    no i do this serval times after that the immo not flash not light on. if i read it again after used first time the dump are not the same i programmed
    Bllinda's Avatar
    Baltic
    Upload bcm h5w, h4.7w and the file that was in the car
    today
    A topic that interests me
  5. The Following User Says Thank You to Bllinda For This Useful Post:
    JFR-Tuning (23rd March, 2020)
    Aug 2010
    Thumbs down here are the dumps
    Orginal UCG
    is
    UCH-N2-X76
    D V4.61
    EEPROM 93C66
    second Hand
    UCH-N2-X76
    H V5.0
    EEprom is 93C66
    von all i write org Dump in advance als a Dump after Replace the second Hand and read again after conect to the car
    Jun 2016
    I have changed this uch many times by just changing eeprom over or copy eeprom data. You either have corrupted eeprom or something else is wrong. Use renault pin extractor , read ori eeprom and extract pin. Then try to program new key to car. You must also just configure uch by telling it what options it has if uch is not from exact same module. Also leave ignition on for 10 mins after eeprom change, switch off and on again. If you here fuel pump running light will be out
  8. The Following User Says Thank You to Briankotze For This Useful Post:
    JFR-Tuning (24th March, 2020)
  9. #7
    Aug 2010
    Quote Originally Posted by Briankotze View Post
    yes that’s is the same I do before Aldo some times. In this case it not works only change eeprom. I have 2 second hand UCH and not work. Both do the same with the dum in eeprom. Do you make the change eeprom by kangoo 1,5 DCI ?
    i will now make it Verhindern and reprogramm it with pin. I have the pin read by Avdi.
    first I test it by 10 min ing on. That I don’t do this.
    i will report. All idea are welcome
    thnx
  10. #8
    Bllinda's Avatar
    Baltic
    It is poorly scanned
    Quote Originally Posted by JFR-Tuning View Post
    Orginal UCG
    is
    UCH-N2-X76
    D V4.61
    EEPROM 93C66
    second Hand
    UCH-N2-X76
    H V5.0
    EEprom is 93C66
    today
  11. #9
    Aug 2010
    Quote Originally Posted by Bllinda View Post
    soory m8 in your cases I have no option to help y ... sorry
  12. #10
    Bllinda's Avatar
    Baltic
    Your Damp is corrupt
    today
  13. #11
    Aug 2010
    please tell me wich dump. there are 3
    1. original car starts and run
    2. second hand UCH origninal befote copy the org Dump
    3. Second hand after prog the org Dump into second hand and make ing on in the car. Than i read it again because car not start also after 10 min ing on
  14. #12
    Aug 2010
    must read 93c66 inb 8 bit or 16 bit mode
  15. #13
    Bllinda's Avatar
    Baltic
    Try .... ....
    today
  16. #14
    Aug 2010
    Try .... ....
    what you mean with
  17. #15
    Bllinda's Avatar
    Baltic
    Read.mw.c66x8.x16
    today
