Page 1 of 3 123 LastLast
Results 1 to 15 of 39
    Jan 2019
    Verona
    Default ABS module renault clio 4 2016
    Hi to all, please someone can help me wit in circuit connection to read the 95640 eeprom of my abs? the enigma scheme does not work because my abs is a little bit different (there is not the same point of connection), i attached the pictures, pleas my car is stop now! thanks a lot to all!!!!
    p.s. is the eprom in the other side of the board? s it difficult to arrive to it?
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by Jacopo89 View Post
    read/write as 95128 and with 4,35 Volt!
  3. The Following 2 Users Say Thank You to drpeter For This Useful Post:
    BigJ (26th January, 2021), PremierD (24th March, 2020)
    Jan 2019
    Verona
    tnk you, but where is the connection pint on the oard to read it? i can use to read:
    -upa
    -xprog
    -carprog
    -digiprog.
    -x-too
    how can i set 4,35v? i tryed to read the epprom with a online scheme but the read is all FFFFFFFFF........
    Rito's Avatar
    -upa
    -xprog
    -carprog
    -digiprog.
    -x-too
    Is Better remove eprom, But if not remove you have voltage seletion in UPA (conections)
    Jan 2019
    Verona
    Quote Originally Posted by Rito View Post
    ok, what are the connection point ?
    drpeter's Avatar
    The Netherlands
    -upa
    -xprog
    -carprog
    -digiprog.
    -x-too
    You read fffff because read/write voltage is too low.
  8. The Following User Says Thank You to drpeter For This Useful Post:
  9. #7
    Jan 2019
    Verona
    i tryed t read5v
  10. #8
    Jan 2019
    Verona
    still error connection 2 ad and connecion 7 bad, someone have pinout (not enigma pinout)
  11. #9
    drpeter's Avatar
    The Netherlands
    I made one today no problem, same connections as your solder points.
  12. The Following 2 Users Say Thank You to drpeter For This Useful Post:
    Jacopo89 (25th March, 2020), rtbdiagnostic (31st August, 2020)
  13. #10
    Jan 2019
    Verona
    Please can you insert the connection point in image i have posted ? Thanks, i’ll use upa
  14. #11
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
  15. The Following User Says Thank You to jomberykaso For This Useful Post:
  16. #12
    Jan 2019
    Verona
    Thank you i’ll try lather end report, the Yellow is 6? I haveN’t to Connect 8 pin?
  17. #13
    Sep 2013
  18. #14
    Jan 2019
    Verona
    Thank you, i’ll try , the image is not definited
  19. #15
    Sep 2013
    picture is not mine, I'm trying to help you only
