Hello can anyone help in reading the pin from the acdelco driver i read the eprom using the I / O terminal
Oryginal ecu is damaged
Thanks.
Thanks.
Try 4A41
Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
Thanks.
It seems to me that the pin should not contain letters 4(A)41
Thanks.
Post a pic of your ECU with the label showing clearly.
OK is my ecu
use this soft and report
Thanks byt not Opel
This is chevrolet corvette c7
Thanks.
@ZIOMAL4340
I don’t even know what you can offer me with zero reputation? Sorry. Nothing personal
A topic that interests me
I can help with crash data airbag I have good solutions.
Thanks.
If You can not find solution here maybe You try this forum:
https://www.corvetteforum.com/
Pin is 9394
Thanks.
