Results 1 to 15 of 20
    AndyCZ's Avatar
    Jan 2014
    EU
    Default HU162 10-4-4 lishi decode help
    Has anyone decoded lishi Audi/VW lock HU162? I decoded like 60/30/30/30 - side cuts and 323533 - conventional cuts.
    Decoded in appl like this. But key not work.Tried mirror cuts - no luck. I bought about 5 HU162 locks on ebay for training purposes.
    Cutted about 10 blades different version. Has anyone ever succeed with this lock?
    If I helped you know what to do..
    Feb 2018
    I dont have hu162t lishi but check hu162 sided bitting calculate.
    I think you must read side cut before opening and after open the lock.
    do the 0,30,60,90 equate to 1,2,3,4 ?
    if so then should the side cuts be 3222 and not 2111 ?
    try cutting as 3222323533
  4. The Following User Says Thank You to u.s For This Useful Post:
    AndyCZ (2nd July, 2020)
    AndyCZ's Avatar
    Jan 2014
    EU
    Quote Originally Posted by u.s View Post
    I see the first four cuts are OK but not opening. I think the side cuts are different. How did you find the first 4 picks?
  6. The Following User Says Thank You to AndyCZ For This Useful Post:
    Oktawian (4th July, 2020)
    AndyCZ's Avatar
    Jan 2014
    EU
    the correct bitting is 3222343133 but the key only lock, not unlock.
  8. #6
    have you tried the following:
    A axis: 3222343133
    B axis: 3222
    C axis: 2333
    or
    A axis: 3323343133
    B axis: 3222
    C axis: 2333
  9. #7
    EDIT: double post
  10. #8
    AndyCZ's Avatar
    Jan 2014
    EU
    A axis: 3222343133
    B axis: 3222
    C axis: 2333
    yes, one side close but not open. The other side not work.
    The second code either will not work. There first four wafers aren't in the door lock. These were meant for ignition.
    This was the door lock for audi A4.
    I used the same logics for:
    A8 door lock - not work
    Touran 5T - not work
    Tiguan Allspace - not work
    Passat B8 - not work
  11. #9
    g5n14's Avatar
    Aug 2018
    Very good topic! Keep it updated. From which year they started doing this side bitting stuff?
  12. #10
    Dec 2012
    EU
    Passat is from 2015 up i think..
    Sent from my SM-G955F using Tapatalk
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
  13. #11
    Oktawian's Avatar
    Sep 2016
    Open the lock and check wafers ...
  14. #12
    Bllinda's Avatar
    Baltic
    Lock ....
    P.S. Pws in PM
    today
    A topic that interests me
  15. The Following User Says Thank You to Bllinda For This Useful Post:
    AndyCZ (6th July, 2020)
  16. #13
    rob h's Avatar
    May 2011
    The locks, that you bought,
    They came with fitting Keys?
    Start compare the readings from lishi, to a working key.
    My guess, lishi 4 cuts, are mirrored, or you Read Them bad.
    0=never 0, IT should display , -10 OR +15.
    4 a 80, 90 OR 100.
    Read of, ones with no pressure, ones with medium, once with fair pressure,
    Right these down, in 3x4 collom
    And about the key, that Will lock, not unlock.
    Assuming youre cuts are of the correct cutting height?
    Using a 1.5mm, and measuring the key After cutting with caliper.
    Or like they said, take one apart, work your way back.
  17. The Following User Says Thank You to rob h For This Useful Post:
    AndyCZ (7th July, 2020)
  18. #14
    AndyCZ's Avatar
    Jan 2014
    EU
    Quote Originally Posted by rob h View Post
    4 a 80, 90 OR 100.
    I have no keys to locks. The picks are correct, these almost new original locks. Cutter is 1.5mm, either machine would not cut.
    I cut about 20+ pcs different versions inc. mirror - not work.
    Once I have time I disassemble one lock to look.
  19. #15
    Bllinda's Avatar
    Baltic
    Take a few pictures of the disassembled locks.
    today
