Results 1 to 12 of 12
Thread: Help Please.
    DK Veteran andymc1s's Avatar
    Sep 2008
    Default Help Please.
    I need help I am an absolute beginner to sat tv, I have a Dreambox 500s and fixed dish pointing at Asra 19.2 . I have flashed box with DK Image version 1.1 and have used DCC, TO FTP FILES TO BOX . the only available camd is Evocamd 2.12 it is not working for encrypted channels,and I dont have a server just a crossover cabe and null modem lead. Ihave read lots of posts but am not able to fix this problem . Is there an Image which already has the required Emu. I hope this makes sense.can anyone help me please
    Regards AndyMc1.
    Sep 2008
    Greetings Andy,
    I'm a new DM500s user too, though I have now tried a couple of images.
    The first one was PLiJade which includes the ccam which made my friends sky free card decode ch4, five, etc.
    The other image I have tried is Darkstar2, on this I needed to use the online download tool to install ccam2.09 which then was able to decode the same as above.
    hth David
    V.I.P. Member Curious123's Avatar
    Apr 2008
    Evocamd is not very good for decoding satellite channels. I don't have DK1 image loaded on any of my boxes so not sure if there is an option to download other cams. You could ftp the cam across but that could be tricky if you are noob. I would follow djrm's advice and load the pli image with the Cccam preloaded and than all you need to do is copy the satankey bundle to your box.
    Sep 2008
    Quote Originally Posted by djrm View Post
    Greetings Andy,
    hth David
    Cheers David I will try the PLIjade and see if I can make some progess
    Thanks Andy
    Sep 2008
    Quote Originally Posted by Curious123 View Post
    Thanks for the Info can I get the satankey bundle on this forum and am I breaking any rules asking these type of questions.
    Regards Andy.
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by andymc1s View Post
    Regards Andy.
    we dont have satans keys on here or any other keys.
    Sep 2008
    Quote Originally Posted by aftermath View Post
    Sorry for asking the wrong question
    Regards Andy
    Apr 2008
    when it comes to satellite recivers google is your best friend.
    Moderator
    krazylegz's Avatar
    Mar 2008
    Crowthorne / Sunny South Shields
    or when it comes to satellite recievers just hook it up to the net and use the addon server
    PS3= krazylegz120282
    please read the rules >>>>http://www.digital-kaos.co.uk/forums/f5/forum-rules-2/
    if you're new to forums and want to make your first post please read here>>>>http://www.digital-kaos.co.uk/forums...ul-tips-30279/
    if you like what people say please use the reputation or thanks button, dont just make a post to say thanks
    Sep 2008
    Greetings Andy,
    hth David
    Hi David have tried Pli Jade but still no joy , but thanks for the help.
    Regards Andy.
    Sep 2008
    Hi Andy, when PLi is installed you need to select ccam as the default cam in the card setup screen, then restart evolution, or just reboot to activate the card. Then you can check that the card is being seen and check its capabilities, The card I used took a while to update before the channels would display, the card had not been used for a year or more. its been fine since. Sorry cant give more precise details at the moment as PliJade is not my current image. David.
    Sep 2008
    [QUOTE=djrm;47799]Hi Andy, when PLi is installed you need to select ccam as the default cam in the card setup screen, then restart evolution, or just reboot to activate the card. Then you can check that the card is being seen and check its capabilities, The card I used took a while to update before the channels would display, the card had not been used for a year or more. its been fine since. Sorry cant give more precise details at the moment as PliJade is not my current image. David.[/QUOTE
    Sorry for not replying until now had to get a new LapTop as my brother dropped my last one . I followed your advice and was able to make progress,
    using cc cam 2.09 . I was able to clear some good chnls with english audio feeds. But now unfortunately they all seem to be switching to Nagra 3.
    Thanks once again for your help much appreciated.
    Andy
