Probably your car missing terminal 30 when BCM going sleep. Check again all fuses, and type here nr of comfort module.
Hi m8s,
I have a problem with Scudo 2.0hdi 2012 year.
When I lock the car with remote control after 5 min I can't unlock it with remote.
Only with mechanical key. I turn ignition on and off and the remote is working again.
I changed BSI with one with same number and programmed everything but the problem is the same.
Does anybody had the same problem?
I think that maybe the problem is in BSM module but can find R03 (9675878080) anywhere.
Can you please help me if someone know anything about this issue.
Thanks in advance.
Already checked fuses 3 times.
BSI module number is: BSI04EV K05-00 0400309 - 96 640 591 80 02
Can you tell me which PIN is terminal 30 on that BSI and from where is coming? BSM maybe?
I wanted to change but can't find R03 9666700280 anywhere.
Any other idea?
Damp upload here ....
A topic that interests me
