Page 1 of 92 1234561151 ... LastLast
Results 1 to 15 of 1370
    Oct 2018
    Default Here codes for VW RCD300/RCD310_RCD500_RCD510_RNS310/RNS315_MFD1,2 RNS510..
    Hello please post here you request .
    Codes available only this radios models for the moments. I worked on algorithm also and is possible code not worked on some partnumbers.I need found this part number and correct the algorithm.I tested this an worked with succes on 85% radios unlocked..~150...250radios,I need here photo with label or serial+part number completed.
    Like VWZ1Z2I4709856 part no 5M0 035 186AA=> RCD310
    Another serials without part number no will try unlock!
    Availabe: BOSCH and BLAUPUNKT
    -RCD300
    -RCD310
    -RCD500
    -RCD510
    -RCD200
    -MFD1,MFD2
    -RNS510 MADE CONTINENTAL (VDO NOT AVAILABE YET)
    -RCD210 PANASONIC (NO ALL SERIAL YET)
    -RCD500 PANASONIC (NO ALL SERIAL YET)
    -RNS315 VWZAZ2....
    -RNS310 BOSCH(ALL RADIOS)
    -RNS310 BLAUPUNKT (NOT ALL SERIALS)
    Make note: No spamming this post with a other radios models,only this can unlock but not all for the moment! Codes send same day instant or with delayed time,because need have acces on me PC...
    After received code please come back with rezult! This is important for me very! .
    Cracked database algorithms:
    VWZ1Z2...: DONE Algo=> database generated!
    VWZ1Z3...: DONE Algo=> database generated!
    VWZ1Z7...: DONE Algo=> database generated!
    VWZ6Z7...: DONE Algo=> database generated!
    VWZ4Z7...: DONE Algo=> database generated!
    VWZ5Z1...: On work..Not found algo yet!!
    VWZAZ2...:DONE Algo=> database generated!
    VWZAZ1....DONE Algo=> database generated!
  2. The Following 62 Users Say Thank You to Walter2011 For This Useful Post:
    4i4o (31st October, 2022), ADEL.KSHLAF (24th October, 2023), allabros (26th September, 2022), alle bmw (3rd December, 2020), ampibali (27th March, 2023), andkl2810 (8th March, 2023), audiopoint (3rd February, 2023), bahaoss (27th November, 2020), baigano (28th July, 2021), berger123 (1st October, 2022), car69joe (9th July, 2022), catalinosonesti (26th November, 2020), chafik4051 (16th November, 2020), danielif (7th February, 2021), dh4736 (19th August, 2022), djelloud (7th November, 2021), electroniquearts (19th October, 2022), er41 (31st May, 2023), fuzz1 (9th October, 2021), gedas8899 (22nd December, 2021), giani03 (16th September, 2022), Ginocar (9th June, 2022), hakan38 (13th April, 2023), HLAVICKA11 (23rd October, 2022), hp7909 (30th August, 2022), hudy26 (21st December, 2022), igorysha (4th February, 2022), julo45 (24th January, 2021), kadi0209 (14th February, 2023), Kanarya (1st June, 2022), koko2023 (14th February, 2023), KOMUTAN (27th August, 2022), kutay demir (23rd June, 2021), maher1800 (18th January, 2023), mido007 (17th August, 2022), MOBILTRONIC (30th November, 2022), mohamad1401 (8th December, 2020), MRAWZIN (11th April, 2023), nelutzul40 (13th November, 2020), nigrou (13th November, 2020), papado21 (28th November, 2022), Papiti56 (14th June, 2023), redwin (3rd November, 2022), resit63 (10th January, 2023), RS33 (6th March, 2024), seal777 (4th December, 2020), sektormax32 (16th March, 2022), sidj (24th October, 2022), skens (14th September, 2022), Tecdiag (15th November, 2020), tiguan (15th November, 2020), Tupacowy (19th July, 2023), wasiesto (9th October, 2022), Wlosy (2nd October, 2023), zabra (29th March, 2021), zappaf (17th December, 2020)
  3. #2
    nelutzul40's Avatar
    Dec 2011
    Ialomita- RO-
    Hi!
    Ned code RCD500
    VWZ5Z7F1045910
    3C0 035 195 B
  4. The Following User Says Thank You to nelutzul40 For This Useful Post:
    jarekmir (27th December, 2023)
  5. #3
    Oct 2018
    Quote Originally Posted by nelutzul40 View Post
    Hi!
    Ned code RCD500
    VWZ5Z7F1045910
    3C0 035 195 B
    Radio code : 0663 or 1663
    Send back report with codè correct if this worked.
  6. The Following 2 Users Say Thank You to Walter2011 For This Useful Post:
    Crasftsman (13th November, 2020), Dekster (13th November, 2020)
  7. #4
    nelutzul40's Avatar
    Dec 2011
    Ialomita- RO-
    0663 work!
    Thank you!
  8. #5
    Feb 2017
    vwz1z2k6262188 3c0035270b rns310
  9. #6
    Oct 2018
    Quote Originally Posted by yon16 View Post
    Send please label photo for this unit...
  10. #7
    Feb 2017
    Quote Originally Posted by Walter2011 View Post
    Here is the photo
  11. #8
    Oct 2018
    Code : 1088 ? (69% sure)
  12. #9
    Bulgaria
    (69% sure)
    How exactly did you calculate it ???!
    I'm not asking about the code, but about the percentages! ??
  13. The Following User Says Thank You to bogege For This Useful Post:
    Zann (13th November, 2020)
  14. #10
    Nov 2013
    Macedonia
    Quote Originally Posted by bogege View Post
    It must be a complicated algo
  15. #11
    May 2019
    VWZ2Z2E2711810
    VWZ2Z2E2333069
    Please thanks
  16. #12
    Bulgaria
    Someone besides me, do you remember who Walter 2011 is? Does it remind you many times of a member of bannat from this forum? Or am I wrong?
    It mostly looks like a member of the"EMITATOR "also its derivative nicknames, but they are many and I will not list them! The old members will remember what it is about!
  17. The Following 2 Users Say Thank You to bogege For This Useful Post:
    attilaa0 (14th November, 2020), simche (29th March, 2021)
  18. #13
    Oct 2018
    Quote Originally Posted by ruobius1 View Post
    VWZ2Z2E2711810
    VWZ2Z2E2333069
    Please thanks
    No can this friend...it is Grundig.... sorry..
  19. #14
    Oct 2018
    Simply: for this serial algorithm generate more codes and after some operation i can see what code possible is correct..some time erorr on first number yet algo not finished...because I need test this on more radios..and serials.I not have 100 radios for test this,on forum easy test this ..
  20. The Following 2 Users Say Thank You to Walter2011 For This Useful Post:
    alle bmw (3rd December, 2020), danielif (14th November, 2020)
  21. #15
    Oct 2018
    Quote Originally Posted by Zann View Post
    Yes complicated,because the algo not same for all part numbers.Some part no serials no generate correct code and I need corect this again..and again..
  22. The Following 4 Users Say Thank You to Walter2011 For This Useful Post:
    catalinosonesti (14th November, 2020), danielif (14th November, 2020), muratasutay (12th April, 2023), paslas78 (21st January, 2022)
